  4. Musings from the shop
fukinitupagianftwlikeabossifitaintbrokefi
136 Posts 22 Posters 2.6k Views 1 Watching
    The gasket between the block and the lower timing cover.
    When I was assembling the engine, I grabbed the gasket and bolted the cover on without thinking anything of it. Then when I got done, I noticed that I had an extra one of those gaskets... odd. By this time I'd forgotten that the other gasket was a different style, so I assumed they had just put an extra one in the package by accident.
    Needless to say, they weren't the same at all. The one that I put in the first time was for an M44 engine. The gasket set that I ordered was only listed as fitting M42s, so I had no idea that there were any M44 gaskets in the set. Luckily nothing was blocked off by the gasket, and everything that needed to get oil was getting oil. I guess it's my own fault for not paying closer attention.
      Saw this today and you've done a great job so far=)
        Thanks Earl.
        It's back together now. No more leaking fluids that I can see. I also got the resonator installed and the exhaust sound a helluva lot better now. There are still a couple small issues that I need to track down, and some things that need to be buttoned up, but it's a runner and a driver now. I haven't gotten on it too hard yet, but the M42 definitely pulls harder than the M10. It's been so long since I've seen it with a hood on, it actually makes me double take when I walk past it. Hopefully I won't have to take it back off again for a while.
          Ah man this is so good to see. An m42 e21 always sounded like a great pair to me
            It's going to be a fun car 😃
              What resonator did you get? Glad you got it together without anymore issues 😃
                Looks gooooood
                  It's the cutest little muffler that you'll ever see. A 7.75"x11" Thrush Turbo. That's smaller than a sheet of paper for those keeping score at home.
                  Overall, I'd say the exhaust note suits the car really well. It's not super quiet like modern cars, but it's not obnoxious like some rice grinder either. I put a nice band-clamp style connector before the muffler at the back of the car, so if I want to make some noise with it, I can drop the rear muffler in a couple minutes.
                  I'm still going to be super busy for the next week or so, but after that I'll get some good pictures of everything and post 'em up.
                    Posting this here for continuity purposes: http://www.wibimmers.com/board/index.php?/topic/3895-no-home-no-destination/
                    Been sluffing off, waiting for a job to come my way here in Madison. Picked up a turbo for a future M42 build (td04hl-16t from a Volvo 850 T-5). Did an autocross at the Road America kart track this past weekend. Had a blast as usual. Even with the M10 I was having trouble putting power down coming out of the corners, but it's definitely gotten worse with the M42. I think I'll be putting the turbo on the back burner in favor of coil-overs, LSD swap, and decent tires. Chassis before power, zee, zee, zee...
                    Looking for some lightweight, low-ET, 15" wheels that won't look redonkulous on an e21. If anyone comes across any, let me know.
                    • The Full BananaT
                      The Full BananaT
                      The Full Banana
                      What engine management will you run with the turbo setup?
                        I'll be switching it over to megasquirt. I don't know if it's really necessary, but I've always wanted to try it out. I'll also be switching to coil-on-plug, and getting rid of the barn-door MAF sensor.
                          Not sure if the wheels I have on my e21 right now are light enough for you or even the right style, but they have nice Falken tires on them. Once I get my group 2 kit on, I won't need these anymore if you are interested.
                            That's a possibility. I was considering a set of those wheels at one time. Which Falkens are those?
                              I can't remember off the top of my head, but I can look at them tonight after work and let you know.
                                No problem. I have no money at the moment anyway...
                                I can dream though... mmm, meaty:
                                http://m.ebay.com/itm/Borbet-Type-T-14x8-4x100-Wheels-and-Tires-14-Wide-Offset-/261564665077?nav=SEARCH
                                  So this popped up on my facebook feed today... Dying
                                    BWWAHAHAHA!!
                                    Good advice. As it so happens, I was just drinking a beer and watching Top Gear...
