  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
  • CMartC
    CMartC
    CMart
    I always hated the way 17s looked, but I later found out that it was because people put little baby tires on them. I went to 17s, because I bought those rims and tired off Dr. Leadfoot with spacers for $350 I believe it was. Couldn't pass that up. Plus I think they fill in the wheel wells very nicely. (I haven't installed my Koni/H&R race setup yet.
    Also, motor tear down in preparation for the new DME/Knock Sensors.
    Excursion 7.3
    E30 LS1
      do the valley pan gasket while you have that open.
      and do the two gaskets on the coolant crossover pipe on the back of the heads.
      both would require this same level of teardown if they start leaking in the future.
      also,
      do a barrel roll.
      • CMartC
        CMartC
        CMart
        Valley pan gasket is $300. I am going to wait to see if I want to keep the motor or not. It isn't hard to tear it all down.
        Excursion 7.3
        E30 LS1
          ?? not sure where you are looking. genuine BMW valley pan is $72. Febi brand is $57. taking the old pan off and scraping the old gasket and using a tube of permatex is like $5
          • CMartC
            CMartC
            CMart
            I don't know either? I just looked again and you are right.
            But where I am now I will have all my parts by Friday so this weekend I am pushing hard to fire her up and burn some tires. A little coolant leak won't hurt (didn't appear to be leaking anyway) until I dyno the motor and make sure she is up to snuff.
            Excursion 7.3
            E30 LS1
            • CMartC
              CMartC
              CMart
              ECU was sent to the wrong address so I am battling that right now. Also, the engine harness I was sent was not the one I purchased so that is fun.
              Definitely frustrating when I have the motivation, but not the parts.
              Anyone know of any good painters that do work on the side? Looking to get some IS skirts and get a paint job over the winter.
              Excursion 7.3
              E30 LS1
              • CMartC
                CMartC
                CMart
                Also need to title the car still.
                Anyone have experience with registering as a collector/classic?
                Thinking about "V 80 30" for the plate.
                Excursion 7.3
                E30 LS1
                  I'm pretty sure if you title as a collector/classic/hobbyist that you don't get to pick what the plate says. I was looking into hobbyist plates for my e21.
                    Hobby/collector plates are just a number in wi based off your collector Id. Dmv page has all the details.
                      V8NSID3
                      S3XMCHN
                      4 PT 4
                        This is correct unfortunately, they just assign you a number. I believe you are also not allowed to drive a car with collector plates in January. Registration used to be a one time fee and then good forever but I don't think that's the case anymore
                        • CMartC
                          CMartC
                          CMart
                          What are the advantages to collector/antique?
                          I don't mind not driving it in January.
                          Excursion 7.3
                          E30 LS1
                            Pay registration once and that's it
                            Only pay to transfer it to a different car
                              Yes it's $200 for first time and there is a specific dmv form to get a temp plate for collector cars in January do year round isnt an issue. As Kaiser said plates are good forever until a transfer is needed.
                              http://wisconsindot.gov/Pages/dmv/vehicles/title-plates/collector-plates.aspx
                              http://wisconsindot.gov/Pages/dmv/vehicles/title-plates/pp-faq.aspx
                                If you plan on putting on fender flares and things like that you will need to get hobbyist plates, antique/collector plates require that the vehicle is fairly original in appearance.
                                Also I was wrong about the perminant registration, I had heard they were getting rid of it
                                  Since they got rid of the permanent registration a while ago, I'd just get regular plates. They are way cheaper and look better, especially on a red car. Your car is emissions exempt anyways due to age.
                                  • CMartC
                                    CMartC
                                    CMart
                                    Yeah, and I do want personal plates in case I ever sell it I will have a memento.
                                    Still leaning towards V 80 30, but probably more appropriate headake sl0 or bstrd
                                    Excursion 7.3
                                    E30 LS1
                                      BSTRD will never make it through the dmv.
                                      • CMartC
                                        CMartC
                                        CMart
                                        I've gotten away with worse.
                                        Excursion 7.3
                                        E30 LS1
                                        • CMartC
                                          CMartC
                                          CMart
                                          RX7 BBK in the mail.
                                          With the suspension brakes and torque this shouldn't make a bad autox machine.
                                          Excursion 7.3
                                          E30 LS1
