  4. 1999 M3 daily driver running log
264 Posts 28 Posters 2 Views 1 Watching
    tsweers89 said:
    A day longer and I would have bought it. Was suppose to go look at it on friday. Nice to see a forum member got it. But seems to have more problems then he told me over the phone and the rust scared me. Seeing the rust on the rear quarters and trunk I bet if you pulled off the sidea skirts there would be holes. Shame you paid so much for it. I had him at $3900 offer accepted over the phone.
    Not sure what he told you over the phone but its actually in really great shape. The check engine light is an o2 sensor, and the rest of the issues are easy fixes. The rust is nowhere near as much as my old e36 and its actually extremely clean underneath. He really undersold the car when he talked about it. For the price I paid (still super cheap for an m3 given what else is for sale, I paid right about the asking price because he had offers of over that) I'm completely happy. It'll be an awesome year round car and I won't be ruining a mint condition car by driving it year round.
    Oh yeah, and if it rusts out I've got a great place to put that low mile s52 :D]
    Edit: checked under the side skirts, clean as a whistle! Not a single spot of rust from what I could see
      Replaced both pre-cat o2 sensors and there is no more rough idle on startup and gas mileage increased from 15 to 22, going to get the codes cleared tomorrow so hopefully it stays off
        Updates!
        Had the CEL reset after the new O2 sensors and it has stayed off for about 200 miles of driving. Picked up some super 90's 16x7.5 OZ wheels that clear the brakes for snow tires. And just nabbed a used but apparently good 140A Bosch alternator for cheap to replace my dying valeo 80A unit. AKG was having a sale on RTAB pocket reinforcements so those will get installed eventually as well.
        The car has been forced into DD duty thanks to Bambi's dad getting in a fight with my e30, so hopefully no new issues pop up.
          Replaced my RSM's with the e46 m3 convertible ones withZ3 reinforcement plates. Drivers side mount was worn but not awful, passenger side had completely failed:
          Fortunately the sheet metal wasn't cracked/ripped in any way!
            Changed the oil with 10w40 synthetic (they didn't have enough 5w40) and popped in some new spark plugs. Running better than ever! Also, passed emissions this morning!
              still not sure how bmw f'ed up so bad on those shock towers. glad you caught yours before they failed. my dad's e36 m3 had to have new towers welded in at about 100k miles.
                What blows my mind is they never really fixed it.  The e46 had the same problem on the rear shock towers.  I'm not sure if any other models suffered the same fate.
                  I think its amazing how easily they fail even when new, and even the upgraded mounts aren't that great. I'm lucky my sheet metal wasn't damaged! It really shows the effects of having computers and simulation software in design work. It allows engineers to easily find the thinnest possible sheet metal and least expensive parts that appease the bean counters and also accomplish the job. I think, in the case of the e36, they went a bit too far in favor of the bean counters in some areas...
                  I repaired my faulty climate control module this morning, following the DIY from Pelican Parts: http://www.pelicanparts.com/BMW/techarticles/Borrowed/e36-climate-control-repair.htm
                  I removed and disassembled the climate control module
                  Located, scraped away the varnish, de-soldered, and removed the faulty capacitor (The blue square component)
                  Once the old capacitor was out of the way, I soldered in a 0.47uF tantalum capacitor
                  Got the unit reassembled and it works great now! The AC blows ice cold and the heat is nice and hot.
                    Got some good work done on the car over the holiday weekend.
                    Rebuilt the cooling system and did the fan delete mod while I was there. Put in a new radiator, water pump, 80C thermostat, aluminum thermostat housing, lower temp fan switch, hoses, expansion tank, and flushed the coolant. I've put 300 miles on it since Saturday and temps have been great even in the heat and sitting in traffic. I will eventually put an electric fan in after winter.
                    I also upgraded my failing Valeo 80A alternator to a Bosch 140A unit. I probably don't need the extra power, but I got a deal on a junk 140A to use as a core and get the proper pulley, so now I'll have all the power I'll ever need for better lights/stereo/etc.
                    I also replaced the faded M sticker and it makes whole back end look way better
                    Before:
                    After:
                    I got the sticker from http://www.donewhenimdead.com/garage/e36-m3-emblem-stripe-replacement, which is way better than buying a whole new badge
                      Nice job man!  I put the 140a in my e36 when I had it because it was required.  The reason for the two options is if you have the ability to have a car phone.  Look in the trunk and if you have the phone symbol somewhere on the left (if I remember correctly.  The guy I bought my e36 from had just replaced the alternator but put in the 80a in stead of the 140a and it didn't make it very far.
                      • i_love_carsI
                        i_love_carsI
                        i_love_cars
                        awesome. Love the sticker overlay for the badge. That way you don't have to worry about putting a new badge on and not having it line up properly.
                        2007 Z4MR
                        2003 E39 M5
                        2002 E46 M3
                        2021 X5 40i
                          I did the same on my e36. Wish they made them for the oddly sized M badges on my M Roadster, ended up having to buy 3 new emblems to correct the fading.
                            uh...http://www.donewhenimdead.com/garage/copy-of-z3-m-couperoadster-doorsill-badges
                              Damn. I couldn't find anything when I looked last year.
                                Might not have made them then lol
                                  That site has been around for awhile but it's really hard to find them unless you are looking for them.
                                    It took me quite a while to find that site for the stickers, its definitely not well advertised...
                                      Replaced the torn intake boot with a non-asc boot and the matching IVC vacuum line. While I was in there I also replaced all of the idler/tensioner pulleys as the bearings were making quite a bit of noise. It sounds a lot better now!
                                      A note to people who care: I recently installed Continental brand accessory/ac belts and they seem almost too short (have to bottom out the tensioners to get them on) and are a HUGE pain to get on/off. Next time the belts have to come off I'll be replacing them with something else
                                        Picked up a new audio system for the M3 from andyhundley along with the e30 parts car:
                                        No idea what brand it is but it looks decent, I'm going to polish it up and install it this weekend.
                                        Replaced the cabin air filter today after work because even at full blast there was almost no air coming out of the vents, and what a pain that was... I was able to "cheat" it in on my old e36 but that trick wasn't gonna work this time, ended up pulling out the glovebox and everything else in the way and finally got it in. The old filter was absolutely disgusting...
                                        Also bought an UltraGauge and mounted it under the headlight switch, its been really interesting keeping an eye on all the things it can display. I highly recommend it as a dedicated OBD2 readout as it is very compact and easy to read at a glance
                                          Installed the exhaust on Saturday, the bolts connecting the midsection to the rear section weren't horrible, only had to use the dremel on one of them which was better than I had expected. Started the car with no muffler on which was fun too, didn't get a video of that though.
                                          Once I got everything bolted up it sounds incredible, I've been driving everywhere with the windows open. I can barely hear it while cruising on the freeway which is nice for longer drives too
