dat grocery getter doe'
"I won't modify this one, I won't modify this one, I won't modi... Ohhhh! Look at all of the aftermarket!"
You should definitely get the LGBT badge and add that as a custom plate.
"Premium fuckery"
I'm dead. Lolol
I seriously told myself this before picking up my saabaru aaaaaaaand it didn't work. Already have a catback, strut braces and springs waiting to go on. However, I will not be doing any engine mods (except the air pump delete which I still need to do).
Famous last words
see what i did there!
WC Lathe Werks shift knob and Kartboy short throw installed. Very happy with the results of the new bushings in there. Shifting is significantly crisper than before. Still not as good as my 135i with BMW performance shift kit, though.
The shift knob is top-notch quality. It cost me 155 bucks which is probably the most expensive shift knob I have ever bought, but it feels fantastic and is weighted perfectly, and the satin finish matches the car interior perfectly as you can see in the picture. The only issue I had was that the etched gear pattern did not line up straight on the Kartboy shifter when fully tightened. It went about 20 degrees too far. I had to rig it with a crush washer to get the etching to line up straight and still be tight.
Yeah, that looks very nice!
