ZHP Exhaust on a 2000 328i?
I think on the 328i's the flange that bolts to the exhaust is at a different angle than a 330 or a 325
They'd be different. Why not just golf tee mod?
Golf Tee Mod?
Summary: Unplug the vacuum line going to the exhaust flapper and plug it with a golf tee.
http://www.bimmerforums.com/forum/showthread.php?1229222-DIY-328i-323i-Golf-Tee-Mod
The 328i should have the flapper. It makes a difference at lower rpms but if he's looking for wide open scream then it won't matter.
I am going to pick it up this weekend. My friend parted out a ZHP so he has a set of sway bars as well which will be a nice upgrade.
Do you know if your 328i has the sport package?
I don't think so. It has base model seats but they are heated. I plan on slamming it and buying a ZHP bumper for it so I can be like all the other cool kids.
Run straight pipes with glass packs. You'll be the envy of your local auto part store chronies.
Reason I ask is that the 328i sport actually had larger front sway bars than the zhp. Just a heads up so your not stepping backwards. Run the vin on bmwarchiv.de
