  4. Build Thread?
Build Thread?
    I think it might be too high of a number for that because I felt something not quite right when I put my m50 together and stopped short of the book spec, I thought it was maybe a mistake as all I had was a Haynes manual.
    Sent from my potato phone.
      I am pretty sure I have done them to this spec every time, without issue.
      The other two that I did before the middle one were fine, so I'm not quite sure.
      Cams are coming back out today, head will be loosened up, oil pan will be loosened, and the front timing cover will be coming out.
      I am getting quick at top end work on 24v motors!
      a5512573-210-pulling%20hair%20out%20cart
        Isn't it 89in lbs?
          Not looking forward to the next update after the picture you sent me tonight.
          I'm starting to feel bad for you now...
            Shop must be cursed man...
              DrLeadFoot said:
              Isn't it 89in lbs?
              Yes, and I had the torque wrench set to 88in-lbs (it was that or 90)
                Well I guess it's a good thing that the front timing cover had to come off. Turns out the drivers side chain guide was busted and flopping about a bit. chain was clearly riding on the bolt type item that holds the guide. I intended to replace this guide anyway, so not a huge deal. Chain is fine.
                To top it off, the cam decided to be a 2 piece cam. I have pulled cams many times, and have never done it any other way than the way I did it last night. It didn't make any noise, no crack, no thud, no clunk. Nothing. Just came out in two pieces. Sweet
                In conclusion, the new shop appears to be haunted.
                Also, this.
                  Homie-G wishes he had a white rav4 sport package
                    2-piece cam for easy maintenance and replacement.
                    That really sucks tho, you're on a roll lately for bad luck. It'll get better soon!!!
                      Went to the junkyard yesterday after I remembered that I had pulled a M50NV valve cover from what appeared to be a good motor.
                      I was hoping that the cam was in good shape, or there at all.
                      I got lucky, the cam was there, untouched, with the cam cover over it. It took me about 20 minutes to tear the top end down and remove the cam, tray, lifters, and bearing caps. All of the parts are in better condition than what was in my motor.
                      Went up to the counter to pay for it, having no idea what they would ask for it. Ended up paying $50 for all of it.
                      Ordered the gaskets and timing chain guide and a few other little bits for the motor to be put back together.
                      Helicoiled the front timing cover, I started with the stripped hole, then decided to do all of them because chances are they would all strip anyway. I will be starting with those bolts first anyway ;)
                        YAY!!!!!!! Your luck is looking up Sir Ben *knock on wood*
                          Turns out the e46 is a utility vehicle!
                            nice!
                            does this mean you're almost done moving out of shop v1?
                              I am out, Alex's stuff is still there (surprise!)
                                I have not updated this in a long time. A lot has happened.
                                I should update this...
                                  yes. yes you should.
                                  assuming there's more details on facespace? :confused:  the rest of us would like to know what's going on.
                                    Not really much on facebook.
                                    Just have been working and not posting about much.
                                      Why? Because I wanted to.
                                      Also, cleaned the oil out of my engine bay. Valve cover gasket blew out a month or so ago. I had tons of blow by, due to those destroyed rings. New motor is sitting on the stand!
                                      • The Full BananaT
                                        The Full BananaT
                                        The Full Banana
                                        I love the Dr. Jekyl and Mr. Hyde e30 pairing you have going there.
                                          That. Is. Awesome.
