The E46 M3 Journal
It's weird that it's going back and forth between rich and lean. That's the only part that has me scratching my head a little. But you said you checked cimpression and it was ok? if compression is ok it very well could be ecu issue. Burger to the rescue! Hopefully you get the issue sorted though. At least you didn't bring it to the people who worked on your e30. Haha.
Needs a new motor.......
Needs a new motor....... Sent from my SM-G900V using Tapatalk
....literally?
Compression is Uber low on all 6 cylinders
Uber low compression s54 > m20
Smite me moderator snap
I will get a new to me motor in there and keep the old one.
Rebuild the new old one and put it in an e36 in the years to come???
I will get a new to me motor in there and keep the old one. Rebuild the new old one and put it in an e36 in the years to come??? Sent from my SM-G900V using Tapatalk
You meant e30 right?
Maybe... depends on the s52.
I just need to get the e30 rocking again.
Yes! Dream build! I'd love to have an e36 with an s54 or euro s50.
I can run regular gas now!
So I've been driving this thing daily. It still gets up and kinda goes when you want it to. Freeway fun time is still fun!
After talking with Kyle, I'm going to pull the head with the motor in the car. Hopefully the problem is with the head.
Cams if I don't have to rebuild the bottom end??
This will happen once I get the e30 running...
