  4. '88 E30
'88 E30
savebigmoney
    holy crap, logged on with a computer,
    Tapatalk takes the formatting and fist phuks it
      anybody have clutch/flywheel/pressure plate recommendations?
      I'm open to opinions
      inb4 stock (im open to that option as well, just curious if anyone has had luck with anything else)
      thanks dudes
        I love my UUC/Fidanza flywheel with e34 m5 OE clutch.  It is spendy though.
          I was looking into grip force setups on their website. They offer some "packages" with the fidanza flywheel option; or their fx racing single mass flywheels. From what I've read some use re-badged LUK clutches.
          Id rather only do this once.
          Here's a link to what some dudes on bimmerforums run and like
          http://www.ebay.com/itm/FX-STAGE-2-RACE-CLUTCH-KIT-14-4-LBS-CHROMOLY-FLYWHEEL-fits-BMW-M3-Z3-E36-S50-S52-/161702586973?vxp=mtr&hash=item25a639aa5d
            The fidanza branded flywheels are made for an m3 clutch. The uuc ones are made by fidanza but machined differently for the e34 m5 clutch just an FYI.
            Sent from my potato phone
              the gripforce stage 3/4 clutches are pretty good! they definitely don't last too long, and they chatter a bit, but man they are cheap and hold power. I have no complaints. But I also would not buy one expecting to not replace it soon.
              that being said, I would probably get a different clutch for this car, especially if you have future FI goals or something.
                FI wouldn't happen for a while.
                How long is "not too long" ?
                  Well I'm not sure what kind of driving you are doing, but about a season of drifting would do it in. I'm not sure how often you clutch kick, but I kick a whole bunch.
                  Personally if I was in your spot and wanted to drive it this summer, I would buy the cheap clutch and have fun all summer. Save up, and don't push it if it starts to slip.
                  Also not sure what kinda position you are for spending money, and how much time means to you.
                    I'm a cheap asshole with no time.
                    I have become the epitome of consumer
                    I'm sure spirited driving will happen. But killing a clutch in a summer isn't on my bucket list
                      I have a cheap flywheel. $150
                        What's the weight on the JB?
                          5$ says the cheap eBay clutch will do you justice for a while.
                          I mean, how long before you can afford the clutch you want right?
                          It takes me about 2 hours to change a clutch on an e30. I couldn't imagine it being much more with a 24v swap.
                          I would rather drive the car now with a cheap clutch versus drive it next summer with a nice clutch(could still do
                          That)
                            I think 13lbs
                              DrLeadFoot said:
                              I think 13lbs
                              that would be the same as mine. I would say its the perfect weight! I mean, I have never had a lighter chromoly one though. I tried a friends car with an alum flywheel and it was not fun.
                                No progress really, just put the pan on after getting a new pickup tube gasket. Also put some ngk plugs in it.
                                Just need to swap the harness from the m50 to the s50. Clean up intake manifold & put new gaskets in it. Clean up TB. Random vacuum line from fpr to intake. Random coolant line to bypass TB.
                                Then all the driveline/clutch stuff
                                Oh and a serp belt
                                How it sits now. I bet the white gets dirty before I even put fluids in it
                                Do have a question: I've read that you need to run shorter bolts to hold the crank pulley on after removing the ac pulley. Some say they ran shorter, others did not. I cannot see anything touching something it shouldn't. For piece of mind I'll probably just get shorter bolts
                                  Where does the small tube go? Pic of line to ICV?
                                  You could tap the valve cover with a 3/4" NPT tap and run braided lines to a catch can.
                                    The small tube plugs into the ICV hose that curls up into the intake manifold
                                      Oh yeah. I blocked that off I think.
                                        Small tube from PCV
                                        970d04d42b10835eb0b2b7fee654f5e7.jpggoes to this little nipple close to the white gasket (top of pic) on the ICV hose which goes into the intake manifold 381b412980a4eeca5bd8b485f08bb46c.jpg
                                        Large tube has those barbed connectors on the dipstick tube it can be connected to. Or I could just run it to a catch can. Instead of having it drain everywhere
                                          Also installed the UHMW PS delete from condor because I was bored
