887 Posts 52 Posters 12.4k Views 4 Watching
    Next up, installing my Rieger diffuser and fxomar side splitters.
    I bought the Rieger diffuser used and the carbon fiber hydrodip was fading. So, I sanded it down with some high-grit sandpaper and setup a ghetto booth in Ben's shop bathroom. Plan was to prime it and then spray it with Plastidip.
    I put a bunch of coats of Plastidip on and it looks great! The finish is a real nice matte black and it seems very durable. The diffuser didn’t come with any mesh, so I went to Home Depot and bought a roll of black gutter guard. It was really cheap, only like $2 or $3. Cut it to size and hot glued it to the back.
    Once I installed the diffuser, the exhaust tips were sunk in behind the bumper. Since this is an aggressive diffuser, I had to get them extended. The tips were always a bit crooked, so this was a great excuse to get everything straightened out.
    Here is a picture I took shortly after buying the car. You can see that the exhaust tips were melting the factory diffuser because they were pushed up against it.
    And here are some photos I took after installing the Rieger diffuser. You can also see the side splitters that I installed at the same time.
      After all these mods, it was time to hit up the drag strip! I only got one video of a pass, but my best time was 12.9 @ 112mph with a 2.15 60ft on street tires. I was heat-soaking really bad and was only able to get 15psi out of the turbos. I guess that is what happens when you sit in the staging lanes for 20 minutes before each run. Next time I'll have an aftermarket intercooler and a more aggressive tune.
      After the races, I went to the streets with a few friends of mine. One of them has a Pontiac G8 GT with intake, headers, exhaust, mild cam, and a tune. He was on drag radials with an LSD and automatic transmission putting out 12.2 time slips. I asked if he'd be down to run on the street because I knew I would have better IATs. I put about 2 or 3 car lengths on him from 60MPH to 130MPH. Then we did a 20MPH roll and were dead even up until about 100MPH. I know I have a 12 second car, it'll just take a bit to get there on the track.
      Here is the only video I have from the track:
        Very cool updates!!  Still a cute car.
          Woah! Some blasts from the past in there!
          Looking minty my friend
            Woah! Some blasts from the past in there! Looking minty my friend
            Thanks guys :)
            • i_love_carsI
              i_love_carsI
              i_love_cars
              awesome dude. Interesting enough I'm in a similar boat, although my clutch was slipping on far less than E85. I just de-tuned to Stage 1 this weekend because my custom stage 2 was causing a lot of slip. I actually slipped bad enough to throw codes and car went into limp mode on Friday - scanned with the AP and found transmission speed not matching engine speed fault code. I've been doing clutch research but there isn't a single mass option for N55. I've got a quote for 200 bucks to resurface my stock flywheel, and probably will end up buying a spec stage 2+ clutch. I was really excited to read about the 550i clutch option and that you had gone that route but then I saw it was only for N54. F my life.
              As for your track times - besides what you already know, get an LSD. Going straight > going sideways. :D
              2007 Z4MR
              2003 E39 M5
              2002 E46 M3
              2021 X5 40i
                From the reading I did, I believe you can swap in the 550i clutch. I also think you can get a SMFW from MFactory, but could be wrong. A little research showed you can use an N54 clutch if you use an N54 flywheel. Don't quote me though, but I found a few N55 people that bought the 550i clutch and never reported their experiences afterwards. I don't know how many miles you have, but I'd replace the flyhweel. The springs wear over time, but I know a new OEM flywheel runs just under $1,000.
                I'd love to get an LSD, but I'm currently battling this issue: http://www.n54tech.com/forums/showthread.php?t=30034
                • dastuzD
                  dastuzD
                  dastuz
                  Well done thread sir.
                  • T
                    T
                    tsweers89
                    Spec 2+ clutch is the way to go for budget minded person.
                      I believe I'm convinced. This might just be my next project street car.
                        Mine is always for sale for the right price :)
                        • i_love_carsI
                          i_love_carsI
                          i_love_cars
                          Rowley, it's hard to go wrong with a 135i for a good street project, as far as late-model BMWs go. You can get N54 cars now for pretty cheap, relatively speaking. The tuning and turbo upgrades keep coming, too. N55 will be coming down more in price too as we are halfway through 2015 already so they are definitely getting older.
                          Suspence, good call on MFactory by the way. I called them and they do in fact have a SMFW for N55 6mt so I'm gonna get one of those along with a Spec Stage 3+ clutch in preparation for my turbo upgrade next spring   :D
                          I probably won't be installing until July after my track days are done in June because I don't have much break-in time this month, but I'll be sure to let you all know how awful it is to swap one of these on the floor with no lift  :lol:
                          2007 Z4MR
                          2003 E39 M5
                          2002 E46 M3
                          2021 X5 40i
                            denialchild45
                            hold me
                              Great to hear. MFactory has pretty good customer service as well. I look forward to your feedback and upgraded turbo... I am looking at a few sets as well.
                              denialchild45 said:
                              hold me
                              I will take this as a compliment...
                                denialchild45
                                Haha yeah. That thing is beautiful man!
                                • e36mpwrE
                                  e36mpwrE
                                  e36mpwr
                                  If you ever decide to sell the ARC-8 call me :) I'll trade my 359M or cash haha
                                  I also have a N54 335i. What tune are you running?
                                    1-series and 3-series offsets are very different, you can probably buy some ARC-8s on their website.
                                    I am running JB4 right now, have been for over a year. I like it a lot, but there are pros and cons to the different tunes out there. I dislike that JB4 is a piggyback where COBB and MHD are standalone flashes. I'd like to try one of Ken's flashes via MHD, but there are a lot of features on JB4 that I like. Boost limiting in 1st, 2nd, and 3rd, meth control, wastegate control (I have bad wastegate rattle), hijacking gauges, 2-step, shift lights, steering wheel controls, etc. It sounds like I could squeeze a little more power out of a MHD flash, but don't know if the tradeoff is worth it for my daily.
                                    • e36mpwrE
                                      e36mpwrE
                                      e36mpwr
                                      suspenceful said:
                                      1-series and 3-series offsets are very different, you can probably buy some ARC-8s on their website.I am running JB4 right now, have been for over a year. I like it a lot, but there are pros and cons to the different tunes out there. I dislike that JB4 is a piggyback where COBB and MHD are standalone flashes. I'd like to try one of Ken's flashes via MHD, but there are a lot of features on JB4 that I like. Boost limiting in 1st, 2nd, and 3rd, meth control, wastegate control (I have bad wastegate rattle), hijacking gauges, 2-step, shift lights, steering wheel controls, etc. It sounds like I could squeeze a little more power out of a MHD flash, but don't know if the tradeoff is worth it for my daily.
                                      I just got rid of mine, and im anxiously waiting for MHD stuff to come (tablet, cable) and also ordered the 7in IC and stage 2 lpfp for e70. All my friends that had jb4 went to mhd and they say the car is something else. Ken is making me a personal map i cant wait to try it out i wish my car was running right when he came to visit us in chicago :(
                                        Is there where you're located, Chicago?
                                        I have Steve's stage 1 inline upgrade, but I'm curious to see how your stage 2 will perform. I have a tablet, but don't have the cable. I'd like to give it a try, but I'm going to get an intercooler, charge pipe, and BOV first.
                                        • e36mpwrE
                                          e36mpwrE
                                          e36mpwr
                                          No im Located in Kenosha Wisconsin. Come down anytime and check it out when my car is ready alot of members have message me to see how MHD does.
