Turbo missing under load
I'll trade you the war chip for the mega squirts seeing as I know how much you love the war chip
Would you be interested in a ms3x?
I am but can send the money on it yet
Great, what are you waiting for then
NOW
I don't need it $550 bad and the 7year wait for it to arrive
i did forget to update this thread its been a while
so it turns out that i had a couple of bad spark plugs causing the afr fluctuation so bad
missing when getting more gas at 9:1 then fine when it reaches 12:1 changed the plugs and stedy at 10.5:1 now no missing
miller performance needs to learn what user friendly really means and fix there software
TCD doesn't deal with Megasquirt?
I make more power lb for lb of boost in my E36 than any of the other locals running other tunes with same/similar builds when using Miller software. Yeah the software is clunky but if you get a proper VM running with XP it works just fine. Plus the guy developing the new software has it almost done, he is local here in MN, I have had some insight on the new build. It's mostly the same with a lot of usability fixes.
He runs MS on all of his cars. I got my board from his buddy who runs PF Tuning.
They don't have a cookie cutter setup. They give you a base tune and that's it. As far as datalogging is concerned, any professional tuner will use their own tools anyway so that part is largely irrelevant for me when considering tuning software. I still make more power than the guys running literal cookie cutter setups that are packaged and sold with a tune already made for it... and I can change shit on a laptop, they can't unless they get a remote tune which requires dyno time. I can go out to the countryside and do pulls, use my wideband's logging capabilities, and go home with a better tune at no cost at all to myself.
Miller's package its just overall Crap for what you get. If you have a competent tuner, you don't need the WAR chip they provide anyways(saving 400$ or so) and the MAF they use is expensive for what You get, as you can buy an HPX maf for 200$ which is what most tuners use anyways(Its just a modified ford slot style 05+ maf).
And in the end it isn't even live tuning or anything! no datalogging, and just as many features you can edit for free. I even have working launch control(user defined) on the stock ecu.
Custom tunes on the stock ecu are the way to go for the lazy guy. There is a local guy that owns a dyno and he can custom tune your obd1 or obd2 ecu, and if you are competent, I will send you all the files you need to tune it on your own(MUCH DIFFERENT THAN MANY PLATFORMS SO DO THIS AT YOUR OWN RISK)
