  4. chit chat thread
chit chat thread
    My last bike. Home-made seat and exhaust. Lots of unnessesary things removed. Light and fun.
    Still have this one, but it needs some work.
      I am burned out
        I need to do a burnout
        Fixed
          You and snap can have a burnout session in 2018
            I do have an e34 you know=/
              I do have a sienna you know=/
                  I recall seeing a premade "harness" of sorts for adding a electric radiator fan... But for the life of me can't find the website (I thought it was on CATuned/Condor/IE....). Needing to get my radiator and fan situation sorted out in the next week or so and SUCK at electrical.
                    Are you removing the mechanical fan?  Or replacing the aux electric fan?
                      B7 with 70,000 miles sold for 20k at the auctions today
                        Wow, that's cheap.
                        I wish I had 20k laying around...
                          I like potatoes, and my post was not what I wanted...
                            Losing the fan clutch, M20 rad, AC condenser, etc... Changing to M42 rad with pusher elec fan.
                              I am a huge fan of the m42 rad. It looks nice and clean. We will see how its cooling capacity is with the m50 turbo...
                              If it doesn't keep things cool, I will run a z3m mishimoto with a shavebay reservoir !
                              On your m20 you shouldn't run into any issues though.
                                ^More info on shave bay reservoir!
                                  Sorry, Chasebay
                                  http://www.chasebays.com/product/universal-chase-bays/chase-bays-coolant-overflow
                                    You should be able to power it from the stock wiring that went to the aux fan assuming it draws less than 30 amps. The on/off is controlled by the temp switch on the right side of the radiator. The one to use is from the 4 cylinder which is 80/88c rather than the 6 cylinder switch that is 90/99c. The are identical other than the switching temp.
                                    Do the aftermarket fans have low/high or just one speed? If just one speed then I would hook the positive lead from the fan to both the high and low wires from the car harness so it runs whether the temp switch calls for low or high speed.
                                    Sent from my potato phone
                                      http://www.r3vlimited.com/board/showthread.php?t=210783
                                      All you need to know
                                        I have that overflow already=) That's what I will be running haha. Whats special about the z3m rad?
                                          Why have hacked up wiring to accomplish the same thing?  If you use the 4cyl 80/88c switch (61 31 8 361787) it plugs right in.  The only wiring needed is to wire your new fan to black/blue AND black/green on his wiring diagram (assuming single speed fan) and change fuse 3 (on the car in his diagram) to a 30A.  The fuse size change is safe because the wiring is the same size on both circuits.  If you have a failed low speed resistor on your stock aux fan you can just bypass the resistor and upsize fuse 3 resulting in high/high rather than low/high.
                                          About the Chasebay overflow, I am confused how you will use that?  It is not a pressurized expansion tank.  Isn't it made for a system with a cap on the radiator?
