  4. '88 E30
'88 E30
savebigmoney
    Ramsey might be interested in the m50.  I am recommending that he m50 swap his e28.
      I have a drive shaft for ya.
        About to text you
          Mitch doing work?!?!
          Bill-Hader-Eating-Popcorn-Smiling-SNL.gi
            Good to know. Right now it's in the car for daily use. It would need to be freshened up
              Still have to get the engine/trans off the tires. Separate trans. Put engine stand together. Put engine from hoist to stand. Move It to heated maintainence area
                Huge progress.
                Moved the oil dry closer to the motor preparing for the inevitable. 5e462d80da77fc40327278261b8edbcc.jpg
                  You can kind of see in the pic above that there is a service door. That goes into a "maintenance" room of sorts. It's maybe 8.5 x 13. (Furnace and water heater are in there) it's insulated & heated by one vent and maybe gets up to 55-60 degrees. The garage portion maybe gets up to 35-40 (not heated, but is insulated on all sides except the garage door -duh)
                  Had a bit of an issue. The engine hoist legs were just a tad too wide to fit through the service door..so the vehicles all went outside and work started on getting shit apart in the garage
                  PB blasted the bejesus out of the trans bolts. Those came off with some leverage. Trans was annoying to slide off because the lack of a load leveler on the hoist. It sucked hard using a bunch of tow straps to get stuff at the right angle
                  It came off except for one hitch, forgot to take off a bolt on the metal thing that goes in between the trans and the back of the engine. Once I stopped being and idiot, the trans popped off. Proceeded to remove clutch & flywheel
                  (I will get pics of clutch and stuff tomorrow, didn't really think of it until later)
                  So with the engine now pissing oil everywhere I started to feel at home.
                  (I grabbed the bag of floor dry from previous post and tossed that crap like it was Mardi Gras)
                  Took the yolk off the engine stand. Bolted it to the motor (used shitloads of washers, because shorter bolts would make too much sense)
                  Getting it to line up to the stand was easy enough-then came going through the door.
                  Long story short the stand didn't fit through because the door didn't open wide enough. So we took the door off and pushed the stand in the room.
                  Finished at 2:35am (mostly due to a run to Walmart @ 12:30am to buy more shit to catch the leaking shit
                  I'm going to tear more stuff off the motor tomorrow and start to clean it (earl should be fedexing me a half pallet of used toothbrushes) Then misplace hardware and never put it back together.
                    This post makes me rainbow
                      Do work! The Mardi Gras sentence made me LOL.
                        Pics that were promised
                        974c9cc13f4cb9c78053542074492871.jpg9942bb49f745399a6e9f12f3e6757eb1.jpgff6dc68af2d5d1ebec25ae1de433e31c.jpg
                          Mid engine Moto-x?
                          Good god man, you need my flywheel!?
                            Gonna get a different clutch/flywheel setup eventually (possibly flywheel from Drleadballs). Everything it pretty much of the engine now. No PS. No AC (just the AC bracket yet) no tensioners no intake no exhaust, etc.
                            I'm getting pretty familiar with the wire brush 6053d62189ca19c16d5d4c89d66b3abb.jpg
                            I really hope that's the only "surprise" I find on this thing
                              DrLeadFoot said:
                              Mid engine Moto-x?
                              lol - most likely, thing looks like it was used to cut concrete
                                http://www.turnermotorsport.com/p-3794-e36-m3-clutch-flywheel-upgrade-package-for-e36-323325328.aspx
                                  I'll make the price right.
                                    The ECS magnetic drain plugs are nice if people actually follow the torque spec. People usually put pan plugs in at NGA and that is why people were snapping them=/
                                      Gotta have that supermoto in at least one pic, huh? :P
                                        Haha. Yep. It's my room mates.
                                        It'll get torn down before the snow melts too
                                          Pics as of 20 minutes ago. It's crusty, but cleaning up alright
                                          Most of the accessories are off
