  4. Musings from the shop
fukinitupagianftwlikeabossifitaintbrokefi
136 Posts 22 Posters 2.6k Views 1 Watching
    Sad :( But hey it's just a car and you're ok! I vote lemons duty now.
      Sorry to see the hit, but glad you're OK. Rear quarter can be pulled if not too bad and the front fenders surprisingly can be pounded back into shape. Depends on how pretty you want it.
      If you decide to put in another engine this one is not free but maybe worth a look: http://chicago.craigslist.org/sox/pts/4848052512.html
      This guy is also on R3V and is parting his late model e30 with body parts in black including bumpers: http://chicago.craigslist.org/wcl/cto/4854955173.html
      If you decide to walk away and part it I expect that there are enough friendly "vultures" here (me included) to help ease your pain with a little $$$.
      • H
        H
        Hammerdown
        sorry to see that Mike.
          Thanks for the support guys.
          I really had my heart set on getting an M42 swapped into the E21 this winter and having a nice driver/fun machine for next summer. "Redneck stepchild" has a nice ring to it though. I'd love to have a beater/rallycross/ice racing/whatever car, but I don't know if I have the time or budget to do both. I guess we'll be playing it by ear from here out. I have another dead M42 in the garage, so if I get the other one, I'll have 3 dead ones to try and make 1 good one and another one to power this thing. Time for plan "F".
            Got the motor torn down last night and took some crappy pics on the way out the door. The top end actually looked great. I didn't inspect them too closely, but the cylinders looked okay too. The bottom end though....
            The worst damage is on the main journals. The bearings were a little melty, which I'm pretty sure is not desirable. Three of them I had to pry at a little to get the two halves to separate. The last bearing at the flywheel end was actually completely fused together on one side, but I think I was able to get them all off without doing any more damage.
            I'm taking some stuff in today to get a professional diagnosis.
              That is kind of cool that the two halves of the bearing turned into one!
              That looks nasty, but its good that the top end still had oil in it!
                Yeah, I'm glad that the head is okay. My other one is pretty bad.
                My visit to Appleton Crankshaft didn't go that well. It turns out the crank can probably be saved. The bad news is that the block is "not fixable". The main caps must have warped, because they don't fit in the block like they should. He said the big ends of the rods are probably bad, but I'll have to check them.
                I've never had a machinist tell me that something was straight up " not fixable" before. For some reason I found that amusing.
                • mkoeppM
                  mkoeppM
                  mkoepp
                  Glad you are okay. Cars can be fixed/replaced.
                    Back to work:
                    :cool:
                      Whoa, wait, what!?!
                        M42 ftw!
                          E21 is getting a valve quantity upgrade. 38% moe powah! Just doing a test fit to see how this is going to work. I have 3 engines now. One is toast and the other two need a rebuild. I was thinking of getting some low compression pistons made and going turbo right away, but now I'm thinking it will be a stock rebuild. It changes from one day to the next...
                            I would turbo it with stock pistons
                            It was very beneficial for me to drive my car around NA on megasquirt for a season to get the hang of tuning. i actually had no intention of running a snail when i bought the MS ecu
                              That was my original plan, but I wasn't planning on having to do a rebuild right away. Also considering skipping the turbo and keeping it NA. I really like the sound of ITBs... Superchargers are cool too though... Lots of ideas, but for now I should really just focus on getting it in the car and running.
                                When you take a ride in bassboys e21 this summer you will know that you need a snail
                                • M
                                  M
                                  michael1972
                                  Turbo that mofo!!
                                    Seriously!! I have m42 exhaust manifold dimensions if you want me to make a flange :)
                                    Are the heads 2 cylinders short of the 24v on the intake side too? I could help you build the intake. I'm building one right now for my car.
                                      By intake, I mean ITB intake.
                                        I believe they're the same, but I haven't really looked into it yet. I've heard of people buying 24v turbo manifolds and chopping them down.
                                        At the moment I'm leaning towards a NA build, but I haven't even gotten the block to the machine shop or dropped the subframe yet so it's a long way off.
                                        Induction noise is a beautiful thing:
                                          Okay because I was working on these today. Getting really good at making transitions.
                                          This is to 2" od .125" alum tubing
                                          I'm getting ready to build some intake manifolds. Velocity stacks next!
