  4. crappy e36
crappy e36
64 Posts 10 Posters 1.3k Views 1 Watching
    Also. The split down the center is just flat? No recessed groves r anything?
    So. Drill .975 or something close, and press in a 1" alum round stock with a 12mm hole, and exactly 49.25 tall?
    • frcefedF
      frcefedF
      frcefed
      Does the sleeve have to be wider than the 49.25 width?
        The split is flat, OE bushing is not split, but these have to be 2 pieces to fit them into the control arm.  You could make the sleeve maybe .010ish (whatever that is in mm) longer than the 49.25mm, it is mainly so the bushing doesn't get pinched too tight, I would drill the center hole at a snug slip fit for the aluminum sleeve.  Between the bushing and the sleeve is where you want the rotation to happen when the suspension compresses.
        • frcefedF
          frcefedF
          frcefed
          When does production start? Haha
            I'll build some this week! They will be Delrin.
            So... I can't do it for absolutely free.
            Price? They shouldn't take too long to machine!
            How many should I make?
            Might order stock to do a good batch of them.
            • frcefedF
              frcefedF
              frcefed
              I will take at least one set, let me know the price!
                Haha I'm asking how much I should charge for them, as I have no idea.
                • frcefedF
                  frcefedF
                  frcefed
                  How much will it cost to make them and how much time will it take per set?
                    finally making a couple sets tonight lol
                      Wait are these rear trailing arms, or rear subframe bushings? Lol. I feel like the rtabs are pretty small. Like 1.5" od or less.
                      Man I lied. I was going to build these, but I thought they were the same as the e30. I need e30 rear subframe bushing and rear trailing arm bushings. Anyone want to measure some? I have a rear subframe I guess I could measure? Paying 300$ for 30$ worth of delrin is crazy talk to me.
