  3. BMW Discussion
  4. 4 door e30 opinons
4 door e30 opinons
74 Posts 12 Posters 0 Views 1 Watching
    Between Valvoline ATF, Valvoline synthetic MTF, Lucas synthetic MTF, and Redline MTL there is a very tangible difference in shift quality when using Redline MTL.
    Between Royal Purple, Redline, Lucas, and Valvoline in the diff I have never heard/felt any real difference between any of them.
    I like valvoline max life 20w50
    For temperatures consistently under 45F i run 10w40
    The engine stays very clean inside and i have never had any issue running the engine extremely hard with that oil.
    • M
      M
      michael1972
      Between Valvoline ATF, Valvoline synthetic MTF, Lucas synthetic MTF, and Redline MTL there is a very tangible difference in shift quality when using Redline MTL.Between Royal Purple, Redline, Lucas, and Valvoline in the diff I have never heard/felt any real difference between any of them.I like valvoline max life 20w50For temperatures consistently under 45F i run 10w40The engine stays very clean inside and i have never had any issue running the engine extremely hard with that oil.
      Ok so some synthetic 20w50 for the diff and am I good with RP in the MT? Thats what I used in my e39 and my e46 M3. and are we talking syn 10w30?
        75w80 for the trans
        20w50/10w40 in the engine
        75w140 for the diff
        • M
          M
          michael1972
          Oh ok. Got confused as to what you were putting 20w50 in. So either or, ir are you saying mix 10w40 with 20w50?
          • M
            M
            michael1972
            Ordered the KYB shocks/struts and the H&r race springs today. Will hopefully arrive before next weekend. If so I willbe installing them Saturday. Can't wait to do some work on it.
            Tomorrow I am going to change the fluids and maybe tuck the bumpers.
            • M
              M
              michael1972
              Boris3 has a thread about Conforti chips being 100 dollars off for black friday from Turner Motorsports so I went ahead and ordered one. Anybody have personal expierence with the e30 chip?
              • M
                M
                michael1972
                75w80 for the trans20w50/10w40 in the engine75w140 for the diff
                How much fluid to fill each?
                • M
                  M
                  michael1972
                  Would 75w90 royal purple be ok in the transmission?
                    I recently swapped the royal purple out for redline in my z3m and was amazed at how much better it shifts. Definitely worth the extra money!
                    • M
                      M
                      michael1972
                      I had the exact oppsite in my e46 M3. Put in RL and it was really stiff espcially when cold. Put the RP in and liked it much better.
                        Strange, I could hardly even get the car into any gear when the car was cold and temperatures were below 45°with the royal purple.
                          20w50 in the spring summer and fall.
                          10w40 in the winter
                          I had the MarkD chip
                          The chips for the eta definitely provide more notable gains. Good upgrade though.
                          Unfortunately you have low impedance injectors (ETA) otherwise id suggest upgrading to a more modern design
                          You could still upgrade but i never studied up on low impedance stock sized upgrades
                            Do you plan on doing an "i" or 885 head swap any time soon? I plan to do the same. Just don't know where to find a head.
                              I cannot keep track of all these rowleymobiles
                              • M
                                M
                                michael1972
                                A few bottomside pics and the engine bay. Kinda looks like the coolant resivor is leaking. Is that a known issue?
                                post-2797-0-14947000-1417295418thumb.jp
                                post-2797-0-54993200-1417295501thumb.jp
                                post-2797-0-13527300-1417295597thumb.jp
                                post-2797-0-79081200-1417295645thumb.jp
                                post-2797-0-53998000-1417295732thumb.jp
