  3. BMW Discussion
  4. 4 door e30 opinons
4 door e30 opinons
74 Posts 12 Posters 0 Views 1 Watching
    Yes=) Especially if you do the i head swap. Then you would essentially have a stroked m20=P
      This^
      I did an "I" head swap and had a 4.10 diff back in the day and I thought it was a beast. This does drop the compression making it perfect for a turbo. Still quick in NA form with the lower comp.
        I have a 4.10 if you want it, it will put you high in the revs on the interstate, I had it in for a 2k mile road trip last summer and it wasn't terrible.  LMK
        • mkoeppM
          mkoeppM
          mkoepp
          Try to get the last seven digits of the VIN and go here to see what it came from the factory with. I love 4 doors. The E28 never came with two :) and that is fine with me.
          • M
            M
            michael1972
            How high in the revs are we talkin if I was cruisen at 75-80mph? And how much would you want for it? Also with 4.10 gears don't you get more tq down low?
              IIRC it was around 3500 at 70 mph.  It will have more acceleration but it was a little too aggressive for DD.  First gear is pretty much useless.  50 bucks?  I just want it out of my garage.  You are in Wausau right?  I can drop it off anytime I am visiting family in the area.
                One way to look at the higher freeway revs is that you are less prone to speeding since you wont want to cruise at 75-80.
                I ran one for a few years.
                Id rather have an S4.10 than any ratio of open diff
                  The one I have is an open.
                  Sent from my potato phone
                  • M
                    M
                    michael1972
                    The one I have is an open.Sent from my potato phone
                    So its not a LSD?
                      Correct.
                      • M
                        M
                        michael1972
                        only reason I would change the rear diff would be to put in a LSD. Thanks though
                        • M
                          M
                          michael1972
                          Well I bought the car today. Just got back from MN. Good thing I am changeing the suspension as it's on original shocks and they are very blown out. The po had records for every other type of maintenance includeing the timing belt a few years ago. But for the life of me can't understand why the shocks were never replaced. The car is superclean but I need a shifter boot. Interior is tan/brown. If anybody has one let me know. I will be in the Milwaukee area tomorrow for thanksgiving and will pick up. Thanks
                            Cool, pics are desired.
                            • M
                              M
                              michael1972
                              So I'm kinda getting scared away from the Raceland coilovers. Am now thinking of doing the h&r cup kit with the race springs. What do you guys think?
                              http://www.modbargains.com/h-r-cup-kit-bmw-e30-3-series.htm
                              • M
                                M
                                michael1972
                                Will his get me somewhat low and get rid of the wheel gap? Or oher sub $1000 dollar ideas. I want to get something ordered tomorrow. Or what would be the lowest springs out there? I can figure out shocks to go with any spring.
                                  My 2c
                                  I think you would be much happier long term with a quality kit like the H&R.  If you want it to be stanced (not dissing that but it is a completely different goal) then get racelands.  If you want a good handling lowered car get the H&R.  I have an Eibach Sport shock/spring kit on my e36 and I love it.  It is not dragging on the ground, I never worry about scraping on a driveway but the wheel gap is gone and it handles great but still rides like a BMW should.  The H&R says a 2" drop in the front which I think would be a great height.  The rear doesn't drop as much because they already look saggy in the rear.
                                  • M
                                    M
                                    michael1972
                                    Thats what I'm looking for. Form and function. All my other bimmers were lowered on springs alone. Just can't stand wheel gap
                                      Don't get racelands for an e30. Even if you want to be stanced out, they won't work for that. For a sub $1000 setup I wouod highly recommend bilstein sport rear shocks, ground control springs and collars, and corrado front strut inserts. Section about 1"-2" out of the front struts and mount the collars and you have the best budget coils you can get=)
                                      • M
                                        M
                                        michael1972
                                        I am not able to weld them back together if thats what you mean by sectioning them.
                                          I'm sure there is someone around here that could do it for you. I ran the Bilstein and Ground Control setup on an e30 I had and was very happy with the results. It's also nice being able to choose your own spring rates.
