  3. BMW Discussion
  4. 4 door e30 opinons
4 door e30 opinons
74 Posts 12 Posters 1.3k Views 2 Watching
    I am a bit biased but... 4 doors work just fine.
        I would assume you mean 325. Sedans are cooler than coupes=)
          They are just fine but having gotten used to the 2dr, getting in and out of a 4dr makes me bump my elbow on the B pillar
          • M
            M
            michael1972
            Yea 325. And I just found out he is the original owner and has all records since purchase.
              Doors preferences vary. I like 2, but I either don't have or don't use the backseat in mine.
              Just a 325? This would be the 2.7 e engine with lower horsepower and a torque curve set up for better mileage (unless the PO stroked it) versus the higher hp and higher torque curve 2.5 325i/is. Both can be fun, depends on your wants/needs.
                This has gotta be a no brainer!
                • M
                  M
                  michael1972
                  yrs, yes it is
                  • M
                    M
                    michael1972
                    Well the rear badge is just 325. So I assume its the e version. Do these suck or what? Will I be able to up the power a little bit somewhat easily with a cai or some other mod?
                      What year is it?  That will tell for sure.  You can swap an "i" head and electronics onto it for an "i stroker" but that may be more than you want to take on?
                      • M
                        M
                        michael1972
                        Its a 1987. I just want a fun little 5 speed to lower a bit and run some autocross for fun. My e92 335i has plenty of go when I need a power fix.
                          ETA's are awesome for daily drivers but not sure how it would hold up in auto cross. 4700 rpm redline would run out quick.
                            You could add a conforti chip for the 325e for a +24/28 hp/tq bump and a new 5300 red line for a bit more go.
                            If you're just looking for fun in autox you'll be fine. Also bring it out to the ice this winter.
                            But if you want to be competitive in autox find another car. Given classing structures in SCCA autox these days and what you have to run against, the e30 is not that competitive in e or i/is forms.
                            • M
                              M
                              michael1972
                              But if you want to be competitive in autox find another car. Given classing structures in SCCA autox these days and what you have to run against, the e30 is not that competitive in e or i/is forms.[/quote
                              In that case anybody have a chip to sell? And yea the auto-x is just for fun.
                              • M
                                M
                                michael1972
                                If I wanted to turbo it would this motor be ok for that?
                                  Yes=) Especially if you do the i head swap. Then you would essentially have a stroked m20=P
                                    This^
                                    I did an "I" head swap and had a 4.10 diff back in the day and I thought it was a beast. This does drop the compression making it perfect for a turbo. Still quick in NA form with the lower comp.
                                      I have a 4.10 if you want it, it will put you high in the revs on the interstate, I had it in for a 2k mile road trip last summer and it wasn't terrible.  LMK
                                      • mkoeppM
                                        mkoeppM
                                        mkoepp
                                        Try to get the last seven digits of the VIN and go here to see what it came from the factory with. I love 4 doors. The E28 never came with two :) and that is fine with me.
                                        • M
                                          M
                                          michael1972
                                          How high in the revs are we talkin if I was cruisen at 75-80mph? And how much would you want for it? Also with 4.10 gears don't you get more tq down low?
