  4. I done did it now... A new toy!
234 Posts 23 Posters 0 Views 1 Watching
    Hallway Pat always has something up his sleeve!
      Will this thing also be getting Stants?
        • M
          M
          michael1972
          Thanks for the pointers! The early 07's didn't come with an oil cooler but could get a free retrofit from BMWNA if it was a factory sport package, which this is. A quick glance through the passenger wheel well when I got home on Saturday and I can see the oil cooler already installed!
          This is the first im hearing of this. I have a early build 2007 with factory sport package and no oil cooler. How do I go about getting this done?
            I believe the car has to still be within warranty=)
              It'll will get lowered eventually.  I don't know about coilovers right off the bat but at least a set of springs until next summer.  I need a winter set up for wheels before I can get a set of summer wheels so that will have to wait until next spring as well.
                What I was told is to contact a dealer first and tell them you need the free retrofit and if they are unwilling to assist you then contact BMW NA and they will help you out.  An employee at Elmhurst BMW gave me this information.
                • i_love_carsI
                  i_love_carsI
                  i_love_cars
                  Welcome to the fold, sir.
                  although now I have an N55 so I can't call myself part of the N54 crew anymore, technically.
                  2007 Z4MR
                  2003 E39 M5
                  2002 E46 M3
                  2021 X5 40i
                  • M
                    M
                    michael1972
                    Only Under warranty or either way?
                      Even out of warranty it should be done.  Shoot an email to BMW NA and let them know you have a factory sport package early model 07 335i and it did not come with an oil cooler and you are concerned with the oil temps and you are wondering if you are eligible for a free retrofit.  From what I have heard this typically takes a few months but is usually resolved favorably.
                      [email protected]
                      • Ryan...R
                        Ryan...R
                        Ryan...
                        The money from selling Lola will go into our savings and either towards fun parts or a k1200rs.
                        Yes. Yes.
                          If you want a supercar you should just turbo your e36 seriously considering its a 328, the hard parts are there. Just big boost and 500whp on stock block and trans all day long. Sounds like more fun than a 335 :)
                          I'm kidding. Kind of? 335's are cool and all. 9
                            Or spend $1.5k on bolt ons and a tune for the 335i and sit at a reliable 450whp / 500wtq. Much cheaper than trying to turbo a 328 E36.
                              Bet I could build a turbo kit for less than 1.5K and make over 500whp on a 328 :)
                              But I understand completely. I'm not much for bolt ons. Totally different type of person :)
                              But I would totally own a 1 series.
                                I seriously thought about boosting my e36 but a full blown project just wasn't appealing to me. Flat out speed was not what I was looking for when I was looking for a car. I wanted something that I can have for awhile, mod slightly and enjoy. Life is coming at me pretty quick right now and a project car isn't on my radar... yet.
                                  N-series engines: torque curves flatter than a marble countertop on a calm lake in the middle of kansas
                                    Ive noticed that. With my m52 there was a definite surge in torque at 3500 up and with this it feels steady all the way through!
                                    • M
                                      M
                                      michael1972
                                      [email protected]
                                      I called them and got no where. I will try shooting them a email. Thanks
                                        No problem.  From what I was told persistence is key.
                                        • i_love_carsI
                                          i_love_carsI
                                          i_love_cars
                                          n series is by far the modern day version of the 2jz. There are people running over 700 at the wheels on stock internals. We still haven't found the limit of the N54 yet. It uses cast pistons but the crank and rods are forged with relatively strong bearings. You can reliably run well north of 500 for a longer period of time than you ever will a NA bmw motor with aftermarket boost (unless you rebuild the engine). There's an enormous difference in an engine that was built for turbo with low-mid range torque peaked for 5k rpm straight, and a naturally aspirated motor that you try to apply boost to.
                                          The reliability as a DD is going to be far superior with a modded N54 than a modded NA motor with a turbo - the N54's stock injectors, fuel pump, and turbos can handle upwards of 20 psi + 30% E85 mixtures reliably. The entire turbo system is built for low-mid range power - you can zip around town sub-3k rpm and still get after it when you need to. I've seen complete teardowns on n54s running 500 wtq at 130k miles that had perfect compression, sleeves were still good, etc. There aren't many cars you can buy, add 200+ wtq to and run reliably for 90k miles. When the only thing you end up replacing are some injectors and a fuel pump or two, I consider that a win. The stock clutch is good to 500 as well.
                                          I've had enough experience boosting cars that weren't boosted from the factory, it causes way more headaches than it is worth most of the time - it has to be a labor of love and creativity at that point for troubleshooting and wrenching on your car  :D Nothing wrong with that, but to me that becomes a project car, not a DD. If you want a sweet BMW DD with power, save yourself the hassle and get something with an N series.
                                          2007 Z4MR
                                          2003 E39 M5
                                          2002 E46 M3
                                          2021 X5 40i
