  4. '04 e46 underside of dash view
28 Posts 9 Posters 441 Views 1 Watching
    FullThrottle e46 said:
    Snap,
    My modules are located in a box under the hood in the engine compartment, whereas the fuse box is behind the glove box. Your pic is completely different than how my car is laid out.
    : O
    Take a peek through the hole here and you may see some fuses behind the glove box :)
    Are you having electrical issues that you believe are due to a shop tampering with it?
    • FullThrottle e46F
      FullThrottle e46F
      FullThrottle e46
      Hey again Snap, do you have a picture of the entire driver's side of the wiring? The thick group of wires that I'm referring to in particular is behind and up from the driver's side foot well panel that goes from right under the steering column down to just above the pedals. All zip ties up under there are black except for this white one that is securing the huge bundle of wires and is located all the way left, and is close/in front of the EWS. Oh, and the EWS is missing one of its nuts and the area up under there is all scratched and scuffed up. As far as the trunk goes, all of the black plastic pins that secure the carpet panel along the inside of the quarter panel (covering battery compartment obviously).
        • FullThrottle e46F
          FullThrottle e46F
          FullThrottle e46
          I'm in my car right now and actually have tried to post a pic but am unsuccessful. I've had my glovebox removed for some time now, and yes, this pic is the correct layout.
          No electrical problems at all and the only shop that had access to this vehicle was the dealership. It's a complicated situation I have and the following and harassing definitely began a week after I took delivery of the car. Three weeks went by from when I first saw the car and immediately expressed my interest to when I actually picked it up. The second individual involved does have strong connections at the dealership and she also found out I was buying this exact vehicle through her cousin who I had lunch with 5days after I started working on buying it. AND he is the only person I told about the car. It's quite possible that someone came in and tedt drove it for an entire afternoon, as that would be the minimum amount of time required for the non Joe-Blow hardwired installation. I asked my salesman if anyone test drove the vehicle and he said he couldn't find that information out, to which I asked him why he can't since they always take your driver's license and a form is filled out too and He had no explanation.
          I have been warned and threatened that I better wait to take final evidence to the police until right before I'm moving out of town because if someone ends up serving time, I will suffer severe consequences.
          • FullThrottle e46F
            FullThrottle e46F
            FullThrottle e46
            Thanks for these pics Snap! Can you post one or two of the wiring higher up behind the steering column as it looks from the factory? Hope so. You're the best.
            • FullThrottle e46F
              FullThrottle e46F
              FullThrottle e46
              Is the purple/white wire also for the ignition? Excuse my ignorance.
                This is quite the interesting predicament. I will see what i can find
                  yes, its the wire you would connect to a remote starter/aftermarket security system that goes to the immobilizer unit
                   unless I am mistaken (someone please correct me if so)
                  • FullThrottle e46F
                    FullThrottle e46F
                    FullThrottle e46
                    *****I overlooked finishing the last sentence, which is that all of those plugs are missing*****
                    • johnprusinskiJ
                      johnprusinskiJ
                      johnprusinski
                      so is someone repeatedly breaking into your car and taking stuff or trying to take your car? I'm confused with your situation, because why would someone who is trying to mess with you put everything back together? why would some one who tried to steal your car bundle the wires and then put a zip tie to make sure you don't notice? if you're trying to get the people who are messing with your car, I would suggest putting a camera or something in your car or around it to catch them in the act you could also park near a camera outside of your apartment complex instead of parking in the parking lot. I don't think you will get any where with a different colored zip tie and dust not being were its not supposed to be.
                      • FullThrottle e46F
                        FullThrottle e46F
                        FullThrottle e46
                        Sorry about some lack of clarity on my part. :o
                        In going back and re-reading there are a few detail that I did not finish explaining. I've gone back and updated one.
                        Ok my problem is there are 2 gps tracking devices that were illegally put on my vehicle and are hardwired in. No one is breaking into my car to steal it. They are trying to break into it to remove these units because they know I'm fully aware of them being there and the signal has been verified professionally. They're fully aware that I'm working with the police and that this is a felony. There's a lot at stake for them (their livelihood and probably serving time, etc..). See we originally thought that the device had to be on the outside of the car and I spent a good amount of time and money pursuing that possibility. I then had someone that was somewhat more experienced and more money and time was spent checking all of the obvious possible areas to check out inside the car. The search was not deep though. Obviously when these devices are installed the placement choice isn't going to be easy or obvious. What I assumed to be an easy task of locating and removing it turned out to not to be. Then, when money allowed again we went deeper by checking the main wiring on the driver's side of the car by removing the footwell panel. That was quite enlightening to say the least. I needed for resources...money and someone with much greater experience. We did not figure out that they had been attempting to break into the car as discreetly as possible until 2 mos ago, and shortly thereafter I confirmed that they were actually doing this to likely a good extent in my supposedly secure underground parking garage at my apartment. I'll also add here that we've been documenting obvious handprints and fingerprints on the outside of the chassis that would cycle and move from one wheel well to another and also both bumpers.
                        • FullThrottle e46F
                          FullThrottle e46F
                          FullThrottle e46
                          I'm determined to protect my evidence and get it out before they get more brazen and get to it before me. I'll be damned if I'm gonna give up or turn my cheek now after 3+ yrs. Specifically, since I took delivery of the car in June 2011.
                            So you had/have a stalker and now they are trying to undo their sneaking devices?
                            Have you disabled them yet or are you concerned about them still being in operation?
                            This is quite a story!
                            • johnprusinskiJ
                              johnprusinskiJ
                              johnprusinski
                              Yes this is a story. I'm wondering what type of person puts a tracking device in a car? A clingy ex lover or the FBI maybe? I hope nothing bad happens to you or your car. I would look into some camera set up or even an expensive alarm system. I remember seeing something like this on vw vortex and the guy stopped posting. Have you located the tracking device in the car?
                                ...like one of those James Bond films.
                                  Oddly enough I had a customer a few years back who brought her car to me to have it searched for a GPS device because her ex-husband was a bit controlling.  The person who took the order thought she was nuts but by this time I had heard enough crazy stories that I didn't even question it.
                                  Your story sounds a bit out there to some people but I believe every word of it.
                                  • FullThrottle e46F
                                    FullThrottle e46F
                                    FullThrottle e46
                                    Neither, John. They have been attempting to get into the car (get the hood open and the trunk) to remove 2 gps tracking devices that they had illegally wired into 2 separate wiring harnesses. My pointing out the additional supporting evidence of finger prints, dust disturbance, wiring harness discombobulation, etc. was just intended to show correlation.
                                    • The Full BananaT
                                      The Full BananaT
                                      The Full Banana
                                      This is amazing.
                                      Also, it sounds like you need a lockbox.
