  4. Well crap :(
Well crap :(
46 Posts 13 Posters 907 Views 1 Watching
  • X
    X
    xgeetx
    Having trouble crow barring the hood open... any tips on how to manually pop a fucked up a hood?
    • I love my E39I
      I love my E39I
      I love my E39
      Hack saw it. you can always use hood pins later. Or replace the support beam
      Sent from my LG-LS970 using Tapatalk
      -Because Racecar-
      • X
        X
        xgeetx
        Got the hood open!
        The radiator expansion tank is completely busted, which now makes me think that my "hoping" the smoke/steam was washer fluid may have been an overheated engine after all :(. Which also means I'm a freaking idiot for thinking I could drive it off the freeway lol. I guess I was frantic.
        The radiator itself looks fine from the angle I can see it... the upper and lower hose connections look good and the aluminum "fins?" themselves don't have any coolant on them. The fan has some broken fins, so i'm not sure if that force pushed hard into the water pump. As you guys guessed, the core support/ radiator mount definitely need replaced. I'm not entirely sure about the bumper... it looks fine but where it mounts on the passenger side would probably need welded or something.
        Also, related to Earl's picture earlier, I think the fender mount is bent at the very end of the bar... not sure how fixable that is. It's not looking good guys :(
        Anybody have an extra expansion tank so that when I get a lot of the front pieces off I can at least start it up and see how it does, or is that a lost cause? As you can tell, I'm not exactly sure what the best "approach" is in this situation, and I don't want to waste too much money at a mechanic if I'm just going car shopping this weekend.
        Edit: Which temperature sensor sends information to the cluster gauge? I know there is a sensor on the passenger side of the radiator... that one is completely busted... but now I'm wondering if the engine temp is fed from a different sensor. Although the expansion tank was totally destroyed, the car never left 12 o'clock temperature...
          The one on the side of the radiator is for the aux electric fan in front of the radiator and A/C condenser.  Only about 30$ for one.
          • X
            X
            xgeetx
            Okay, thanks. So the one for my temperature gauge is actually on the engine? If my temp. stayed at operating temp the whole time, should I be safe with regards to an overheat or is it just too hard to say?
              You are quite possibly fine, the temp sender for the gauge and ecu are both in the head itself, they are on the intake side below the intake ports around cylinder 2.  I forget what year your car is but obd1 has 2 separate sensors, obd2 has both in one sensor.
              • X
                X
                xgeetx
                Separate sensors for what? 1 for gauge and 1 for ecu? Mine is 1998 so obd2 I think.
                  Yours is OBD2. He means you have one sensor that talks to both the gauge and the ecu. OBD1 has two sensors. One talks to only the gauge and the other only talks to the ECU. If your gauge stayed at 12 o'clock you did not overheat your car.
                    Yes, the obd2 sensor has 4 pins on the connector, you are obd2 in '98.  The obd1 has 2 different sensors right next to each other, one has 1 pin and the other has 2.  I have an Autometer water temp gauge so I replaced the gauge sender in the head with that one, I leave the stock sender plugged in hanging in the area behind the oil filter housing to roughly measure underhood temps.
                    • X
                      X
                      xgeetx
                      Thanks guys. Earl, I'm going to post some more pics tonight to show the damage to that fender mount area. Also the piece of metal that wraps over where the strut bolts in and comes down to the front of the wheel well is pretty messed up in the corner. I don't think it affected the tire or suspension, but that may also be something that can't easily be repaired. When I post them, if you could give me a best guess that'd be great :D
