  4. Build Thread?
Build Thread?
    Yesterday the car saw daylight for the first time in a year and a half.Ā
    Car got taken to a guys place for exhaust, was hard leaving it behind lol
    I want to work on it, but it is no longer at my house. Kind of disappointing!Ā
    Cool panorama for the kids
    • 3
      328ci
        http://truckyeah.jalopnik.com/vigilante-who-shut-down-a-car-chase-rewarded-with-new-t-1597679512/+ballaban?utm_campaign=socialflow_jalopnik_facebook&utm_source=jalopnik_facebook&utm_medium=socialflow
        The comments on that are goddamn hilarious
        • C
          C
          Corky325
          Your rear tires go on the dolly while the fronts roll... unless you don't have a diff in of corse.
            I was thinking the same thing.
            Did you make an 'oops'?
            šŸŽ¬ YouTube channel (60K+ subs): youtube.com/jakespence135
            šŸ“· Follow me on Instagram: instagram.com/jakespence
            šŸ Shop BMW merchandise: bimmerstreet.com
              I have never seen it or heard of it done that way. And a quick Google search shows 98% of cars with the front wheels on the dolly.
              Why risk having the front wheels track wrong ?
              Edit: U-haul's website and instructions also state that the car MUST have the front wheels on the dolly.
                I have never seen it or heard of it done that way. And a quick Google search shows 98% of cars with the front wheels on the dolly. Why risk having the front wheels track wrong ? Edit: U-haul's website and instructions also state that the car MUST have the front wheels on the dolly. Sent from my XT907 using Tapatalk 2
                There are mixed feelings about the right way to do it. The front wheels should lock with the steering column, so you shouldn't have to worry there.
                U-HAUL is just trying to cover their ass with that statement. Unless you're AWD (which you're not), I think you'll be just fine.
                  You're just putting miles on the car that aren't actually being driven=) I would rather do that than trust the steering lock
                    It's not like he's going a long distance
                      Odometer is not cable, it uses the VR(?) Sensor in the diff. I don't have my battery or anything of the sort plugged in. I don't even remember if the odometer works on it lol.
                        Correct, it will not count miles with the key off, the odometer is driven b a stepper motor inside the speedometer.Ā  Should be fine to tow like that, Never tow a RWD auto trans with the rear tires rolling, the trans is what gets damaged from improper lubrication.Ā  This is why it is common to remove the driveshaft on a truck being towed in this way.
                        '05 Volvo V70R, 6spd.Ā  200k
                          So, I picked up the car from Mr. Exhaust's house yesterday. He was an awesome guy to work with, we would communicate pretty much daily about details of the exhaust and getting progress pictures and he charged a very reasonable rate. His welds are fantastic, and his pipe routing is exceptional. I am extremely pleased with how everything went and the turnaround time.
                          Exhaust Specs: Everything is 304 stainless, 16ga (actually a little thicker), 3" mandrel bends.
                          3/8" turbo flange -> 30 degree 2.5" to 3" roll cone -> 3" v-band halfway down the downpipe -> flexpipe under passengers feet -> 24" stainless resonator -> 3" V-band before subframe -> 3" to dual 2.5" split -> Tips
                          Wastegate is also tied into the upper half of the downpipe.
                          He spent 25 hours to make it what it is, and I don't think it could get any better. I will get some more pictures later, before and after heat wrap!
                          My fuel lines should be here on Tuesday (after waiting over a month) and after that I cannot think of too much left to do before getting it on the road.
                          Started breaking in Tim's (Deadskittles) car, the built s52. That thing is a monster, 3/4 throttle in 3rd and the tires don't hold too well. Videos of that later as well!
                          • 3
                            328ci
                            Cant contain my excitement
                              Cannot wait to see pics, I've been trying to figure out the who/where/how of my exhaust for this winter!!!
                                I will be able to work on it tonight so I will get some pictures.
                                The date stamp on your post is 12/31/1969 lol
                                  So, I finally had some time to work on the car last night. Was able to get the exhaust out and wrapped, but did not get the exhaust back on entirely. My fuel lines (that decided to start leaking) will finally be here today so those will go in the car.
                                  Pictures!
                                  So all in all I am super happy with how it turned out, and it most certainly came at a cost. The exhaust is crazy high up in the car for being 3" , as you can see the lowest spot is probably less than half an inch below the frame rail. Compared to what other exhaust I have seen it is very impressive.
                                    Looks awesome. Very good quality. You forgot pics of the tips!
                                      New fuel lines went in today as well!
                                      • 3
                                        328ci
                                        This must be getting very close to being road ready
                                          Blew the fuse on the battery , my fault. Luckily there is a fuse in line. Now to put in a replaceable one!
