887 Posts 52 Posters 12.4k Views 4 Watching
    I have a video in the works. Just need more time to film and edit.
    Expect something awesome late next week...
    Includes obligatory tire shredding. I'll also try to have someone film me putting an R6 in the dust.
    • 3
      328ci
      I havent had a ride since all the new goodies, youre gonna need to give me a spin when I get home  :cool:
      • M
        M
        michael1972
        Awesome. What downpipes did you go with? Sure glad all my bolts came out easy as pie. That must of sucked. I have been running a 35-36% e85 mix now and its sweet. Also planning on getting the FP upgrade and a backend flash so I can run a stronger mix. Do you know someone that can do the flash or are you going to try yourself? Also would you be interested in runnin em for fun? Maybe down at Dubs in the Valley. Hey, did you change your IC yet?
          For sure, sometime next week should work.
          I went with the 3" VRSF downpipes. The install did suck, lol.
          I know someone that did the flash for me, but I'm thinking about buying the cable/software to do it myself. I'll let you know what I decide to do, otherwise PM me if needed.
          As far as lining them up, let's do it! It would be interesting for sure. I haven't changed my IC yet, but an upgraded 7" IC from VRSF is on the top of my shopping list.
          • M
            M
            michael1972
            So your allready flashed for running more e85 but still on stock pump?
              I added the inline pump at the same time when I flashed. I'm running the BMS E85 flash right now, but am going to switch to a Wedge flash this Sunday.
              Check my website: www.My1Series.com, it's the first post you'll see.
              • M
                M
                michael1972
                Well in that case you would have a big advantage on me if we ran em. Gonna have to wait till I bump up the e85.
                  To be honest, I didn't notice much of a difference after the BMS E85 flash. It was a similar to the difference I felt after the downpipes. Either way, I'm going to have the weight advantage ;)
                  • M
                    M
                    michael1972
                    So you noticed as much gain has when you installed the dp's. To me that sounds like a significant gain.
                      I think my butt dyno is broken. The only mod I really felt was JB4. The rest weren't as noticeable.
                        Check the two newest posts on www.My1Series.com!
                        I replaced this crap:
                        And changed the spark plugs:
                        There are more pictures and background info on the site.
                        I had no problem putting bus lengths on an E39 M5 today. The car is a beast.
                          Most e39 M5's are pretty weak......I say most.  We'll line 'em up when I get mine done (someday.....long ways away, hahaha).
                            Last year when my friend had one (the one you met at Beyond Redline), I was pretty impressed with them. They're definitely nothing to laugh at.
                            Get her done already!
                              Scored a used BMS dual cone intake kit for $25! It sounds awesome.
                              Read my blog post about it here: www.My1Series.com
                              Also, you guys love videos here. I had Ben come over and put the GoPro on for a few pulls. Sorry about the wind noise!
                              First two pulls are 2nd gear. Third pull is 1st-4th gear to 140mph. I let off shortly after passing the car on the left.
                                This car has been in need of a good detail and I finally got around to doing it this weekend. First I washed it and went over the whole car with a claybar. I was surprised at the amount of crap the claybar took off. Then I took a picture before I started the cut/polish/wax process. Once I was finished, I took another picture to show the results.
                                In the photos, you can see a lot of things in my garage reflecting off the paint. The two lines near the middle of the photos are power cords, not scratches. The lighter reflections above those are the power boxes on the light stands. All other bright imperfections are either lights on the ceiling, lights on the stands, or bright objects laying on the ground or on top of shelves. Obviously you can see the reflections of the yellow and red light stands themselves.
                                I was able to remove about 95% of the imperfections from the paint with this process. The 5% of imperfections that remain are very hard to see unless you're inspecting the car under harsh lighting. It just goes to show how awesome the car looks/feels now. Keep in mind, the "before" picture is when the car was already washed and clean. The marks you see are all swirls or scratches.
                                This is an animated GIF, it will switch between images.
                                As you can see, the photos also show the metallic pretty well. It is easy to see in person but hard to notice in photos. Black Sapphire Metallic > Jet Black!
                                Said and done, the whole process took about 10 hours. I even wetsanded a spot on the rear bumper to get rid of some weird hazing. Well worth it to me.
                                  Looks great, I just did a hand polish with Griots Garage "One step sealant" on my '89 and it made a huge difference.  The one step sealant is a fine polish and paint sealant in one, I unfortunately don't get around to taking as much care of the cosmetics as I would like and it is a longer lasting than a wax.
                                    Thanks man. I actually used a high-speed corded drill with a velcro attachment for cutting, polishing, and waxing. This was my first time doing any sort of paint-correction and I am very happy with the results.
                                    To see a list of products and the process I used, check out the post on my website.
                                      Have you machine cut/polished a car before at all? That's one skill I never got around to learning at the dealer that I wanted to.
                                        The car looked great at Dubs in the Valley man!  Wish I had a chance to meet you!
                                          Never. I've applied wax by hand with a small foam pad, but that's it. I bought a 7" variable speed polisher from Harbor Freight for this, but it was too much for me. It was hard to use and I didn't like it. That's when I opted for the high-speed electric drill, it was the perfect speed and very easy to use compared to the large polisher.
                                          Thanks! Same here. Your car looks very similar to my old E36... except mine was a coupe.
