  4. M20 intake manifold design thread
55 Posts 13 Posters 978 Views 3 Watching
    Chris sent me a picture of a different M20 pvc manifold. What a bunch of trolls.
    • JeffJ
      JeffJ
      Jeff
      Do they help in any aspect?
      1976 530i e12
      1990 325ix e30
      1992 325i e36
      1995 740il e38
      2001 330xi e46
      ^More to come :)
        smooth surface finish, but plenty of ledges for air to "trip" on and become more turbulent.
        Probably weighs the same as the cast aluminum manifold to boot.
        Looks like garbage.  Someone needs to start an  "E30 engine bays that look like crap" thread.
          I really like where this is going! We have a unique opportunity here :) I have all the tools to build an awesome manifold for us, but we simply need to design it! I think it would be cool to post all the files publicly as well so people could have them built. I can only fathom building 5 or so at first :)
          We can do this at an extremely affordable cost too! I could even build a die to form the velocity stacks, to save mucho moneys(or not).
          There are many ways we can make this really affordable! I want to kill as many crab manifolds as I can....
            Right now im  on board with what Jeff is doing. Lop the flanges off, weld on some 6061 tubing for the runners and probably pipe, plate, or a combination of both for the plenum. Super simple stuff.
            • JeffJ
              JeffJ
              Jeff
              I like simple. I have to sit the flange in half so I can cast it to make duplicates for different manifolds. We need to figure out the optimum runner length and plenium size. Also shape or the plenium has factor too round oval square triangle what makes what difference. The volume inside the plenium is also needed
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
                My design priorities are
                -Equal cylinder filling
                -Minimal flow loss
                -Plenum size and runner length beneficial for low rpm off-boost performance if possible.
                -Manufacturability
                -Low weight
                -Acoustics
                -Engine bay cleanup/ease of maintenance
                  -Minimal flow loss
                  -Manufacturability
                  -Low weight
                  -Acoustics
                  Perfect! Exactly what I'm after.
                  Can't wait to see some numbers so I can order the runners :) that's all I need to build 3 or 4 of them.
                    If at all possible I would like to use the stock throttle cable as well
                      No front(angled) entry?
                        I havent looked into generic throttle cables much but yes id like the tb to be front mounted
                        • JeffJ
                          JeffJ
                          Jeff
                          Why front mounted vs side mount?
                          1976 530i e12
                          1990 325ix e30
                          1992 325i e36
                          1995 740il e38
                          2001 330xi e46
                          ^More to come :)
                            I personally like it for packaging reasons, and long radius(and short in length)  intercooler piping
                            • JeffJ
                              JeffJ
                              Jeff
                              I think there needs to be two different ones designed here 1 for the guy that is going n/a and one for the turbocharged monsters
                              1976 530i e12
                              1990 325ix e30
                              1992 325i e36
                              1995 740il e38
                              2001 330xi e46
                              ^More to come :)
                                ^Agreed=) There should be an m42 manifold made too=D
                                  Dear Earl,
                                  2 nights ago I had a dream that I swapped a rebuilt M42 into my car (with my current turbo and such).
                                  It sucked. true story.
                                  sincerely,
                                  Snapple
                                    I would hope so! They are two totally different beasts(not exactly)
                                    If i wasn't FI I would definitely use ITB's or triple webbers or something
                                      I'll be supplying the chips and soda for this debacle - so let's start with the hard questions:
                                      Doritos or Sun Chips?
                                        On a more serious note: I'm 100000% in for this.
                                        -I like the "front" TB inlet to allow for easy integration of IC cooler piping later (wink-wink).
                                        -My previous SRI was built by a gentleman on the east coast who specialized in such things. Acouple design things to consider: vacuum ports and locations. TB flange variations. Integral fuel rail mounts.
                                        -I'll have to find the data - but I recall reading a lot of research on having the full bell radius stacks "flush" with the plenum side VS extending "into" the plenum when researching my previous mani. Extending "into" was the winner for all applications.
                                        -Gotta look good (design/fitment/welds). I ❤ pretty stuff.
                                        My previous SRI off my MK3 ABA:
                                          ^^^That manifold had the full bell radius stacks extending into the plenum. Sounded AMAZING at WOT, nice gains in upper RPMs as well.
