  4. e36 ball joints..?
e36 ball joints..?
4 Posts 3 Posters 53 Views 1 Watching
  • brehmerB
    brehmerB
    brehmer
    I just bought a 99 328is and it needs outer lower ball joints. Can I replace just the ball joints or do I have to get the hole lower control arm?
      You can replace the joints but replacing the arm with new joints installed is preferred.
      Which do you prioritize higher: keeping costs down, or making the installation painless?
      Also, are you looking for performance or comfort?
      • brehmerB
        brehmerB
        brehmer
        For now I just want to keep the cost down I blew most of my budget on the car but its rust free so it was worth it.
          It is 100% possible to do just the joints and you can rent a ball joint press from Advance Auto.  I was fortunate enough to use an impact and a ball joint press at work to do a few.  It is really not that much more difficult to save yourself the $100.  You could also make friends with a shop and they may only charge a few tenths of an hour to do it once the arms are off.
