  4. 94 325I E36 Rear shocks leak instantly
14 Posts 5 Posters 111 Views 1 Watching
  • A
    A
    andrew4g63
    I think the springs is the route we are going to try next.  I will get into it and post the results.  Thanks.
    • A
      A
      andrew4g63
      Update: The owner of the Mueller Motorwerks, who provided the struts called and told me how the shocks and struts (from Bilstein and Koni) will be over full with fluid and after a short drive they will leak.  Wash them and test drive again and they should be fine.  I will post the results.
        Well I have never heard that before.  That's interesting.
          Ditto
            x3
              x4
                Came across some forum posts that Bilstein shocks seeping is supposedly ok / normal but dripping is not????
                • A
                  A
                  andrew4g63
                  So i have washed them and driven the vehicle multiple times and the fluid is still coming out.  It is not as much as before but maybe because they are running out of fluid?  I also agree in my 15-20 years in auto parts, repair and management iv'e never heard of this.
                    I am not sure why that would be acceptable in any case. If they are overfull, they should not fill them so much at the factory. They obviously aren't using Poka-Yoke
                    • A
                      A
                      andrew4g63
                      I agree.  Not impressed.
                        I know that Toyota has a "tolerance" for seeping/ leaking struts/shocks and bases most of their replacement recommendations on mileage.  I always based recommendations on mileage and visual inspection.  I have never heard of an aftermarket saying that it is normal to have any seepage immediately after replacing a shock or strut.
