My new 1995 540i/6
My dad and I did did the oil change/tire swap, first real maintenance done since We picked this thing up. Changed with Mobil 1 15w50 synthetic and a BMW oem filter my dad had lying around from his old 540i.
Ben was pretty happy to say the least!
That sounds menacing! I wouldn't change a thing on that exhaust! Wheels look good to man. Style 32?
The exhaust has opened up a lot now that it's gotten warmer out. It has a nice tone while cruising.
Thought I would do a little update. Didn't end up getting any work done last sunday but that give me more time to get some parts together. Does anyone know where to get or have a BMW Bushing Puller Tool? I need one to get the subframe bushing job done and I can't find anywhere to rent them online. Do dealers have them or possibly A to Z? Anyways I want to get that done in the near future and once that is finished I'll be replacing either the control arms or more of the front suspension as well. I found some kits, http://www.fcpeuro.com/products/bmw-control-arm-kit-6-piece-e34-e346piecesteel-l and I have to figure out if I have the money to do more then just the control arms. There is a some shaking in the front drivers side when I brake lightly and people online seem to say that is the problem. Also when I tried replacing my fog light bulb the light wouldn't come out the front of the valence like the bentley said it should. It is stuck on the left side of the light somehow, almost like the light is to big for it to come out the front but it can't go to the back either. If anyone has some tips feel free to chime in. Also please let me know if you know anything about BMW Bushing Puller Tools.
In other news, I went to cars and coffee with Chris and a couple friends from Waunakee. It was awesome! My car showed up on the Car & Coffee Facebook page, here is the pic.
Pat also took a video from his phone but its on Facebook and we've had some problems trying to get those to play on here so he will have to post it if he wants to share. It was a great time hanging with people from the forum and meeting a couple new members.
i will try and get that posted up tonight for you Ben!
Congrats on a really nice car! Had a couple of E34s when I was in Germany a few of years ago. Was looking to buy one when I got home in 2012, but ended up buying an E30 Vert instead. Would still love another E34, but, don't have the money or room for another car. The vert would have to go.
Uploading... uploading
Voila!
i may or may not have witnessed this car do a burnout in brookfield square.
it was awesome
it was awesome
That was my first experiment with no traction control so thats why it was terrible
I did get it into a second gear burnout though
. There may or may not be a burnout at scooters this weekend...I really dug being parked next to your car at the E30 picnic. Our paints look so different next to eachother and your wide grilles and m tech kit make your car look much different=)
Are you going to any of the meets in Milwaukee this weekend? I would like to meet your green e34 since we have this club going.
Voila!
Thanks!
I will be at Scooters Saturday. No burnouts allowed however
nonsense chris.
bushings can wait...
burnouts bring babes and babes dont have time for bushings
nonsense chris.
This statement makes more sense than anything else on this forum. This should be our mission statement.
So while this guy is off doing Naval training down south....
The car has been residing at the Bimmer HQ in Sun Prairie and my father and I tackled the Rear subframe Mount bushings last weekend. Wasn't surprised at all when we started taking things apart that there wasn't much left of the bushing itself.
The bushing puller tool borrowed from BenDem ended up being to small as the E34 bushings are bigger than those on a E30/E28. So we ended up doing some creative engineering. We followed the instructions on this page for the basic steps http://www.bmwe34.net/E34main/Maintenance/Suspension/SubframeBushing.htm
As for the puller, we bought a basic gear puller at Harbor Freight and along with threaded rod, nuts, various sized washers and u-bolt plates from Menards. Essentially we had a pyramid of washers on top of the bushing, ran the threaded rod through the middle with two nuts on top of the washers and then through the puller with a coupling nut used to turn the rod. We had to add a large band clamp around the arms of the puller to keep them from popping off which worked quite well. Once we had a start on the bushing, using a propane torch to heat the outside of the sub frame mount they slipped right out.
Didn't take any pictures of the installation rig but it was basically the same setup except we placed two metal u-bolt plates on top and ran two threaded rods down the sides into the H-plate of the puller. These replaced the puller arms. By tightening the threaded rod on each side it pushed the new bushings into the housing. Below is the end result! I can't wait to have a lift...
Ride quality greatly improved! New plugs and rear brakes are on the list of to do's before Sunday when Ben leaves down south for school. I still have yet to find out where this occasional coolant leak if coming from
I'm still weary on doing burnouts as there is still a slight driveline vibration in 1st/2nd. Ben bought the Guibo and CSB for me to replace while hes gone but I'm thinking the rear CV joint on the drive shaft might be the issue. I didn't feel any play in the CSB while under the car and the guibo just needs replacement for age, otherwise its holding up. I'm not sure if I wanna mess with taking off the exhaust system either so these items might have to wait till winter. I'll do some more investigating tomorrow afternoon at the shop.
Saturday I ended up doing some last minute work on the car while Ben was flying back from Virginia. Bought a set of ceramic brake pads to replace the rears only to find out the pads on the car are basically new. Looks to me like the rear calipers are sticking slightly so time for a rebuild.
The car started a little roughly after finishing the sub frame mounts last weekend, so figured it was time for new spark plugs.
In case you wondered what a M60B40 looked like naked...
I knew the drivers side valver cover gasket was leaking when I bought the car but it was only visibly leaking on the back of the head, but never left puddles. Now I know the oil was leaking down in the spark plug wells. Took me a good hour or so to soak all that out with paper towls.
Not sure when the plugs were last changed but they didn't look too bad.
Replaced them all with Bosch plugs and cleaned it up. Special shout out to Kaiser for the 11pm service adivsor call. I've never changed plugs on a car with coil packs so I learned they just kinda sit there instead of popping on like the caps of a plug wire. Thanks bud.
Fired right up without hesitation and definantly felt some power gained back. Next morning after a big breakfast with the family and some of his friends Ben got the car all packed for the maiden voyage down south.
Putting the engine covers back on
All packed and filled the tank.
Good news, he got 26mpg on the way down and even maintained 25mpg through the mountains. Bad news is down near Charlotte, NC he had to pull over due to some severe front end vibrations. I was on the phone with him on and off for most of this morning. We are thinking his front calipers probably stick too and he noticed he had a vibration clip missing from the passenger side where the wheel vibrations were coming from.
I had checked out the driveshaft and it seamed pretty solid by feel but apparently the vibrations have gotten a lot worse too. Car had been driving normally over the past two weeks so it kinda sucks that things went south as well you know he went south
Looks like he'll have some weekend projects to take care of over the next two semesters. -
The vibration clip i assume you are talking about for the brake caliper? Really does almost nothing. Just for anti rattle. WOuld have nothing to due with your vibration.
Figured so but worth mentioning. Car needs control arm bushings pretty badly along with most other suspension bushings at 260k+. Basically this car needs a baseline on suspension and driveline.
