686 Posts 32 Posters 8.9k Views 3 Watching
    These last 2 weeks slipped away from me, I was hoping to drop off a bunch of parts for paint before Scooters (front valance ducts, DS mirrors, etc...). Summer is always alittle crazy for us.
    We're starting our "summer hours" this week at work, which means I'll get one afternoon off a week on a rotating schedule. Hopefully those afternoon/evenings can get a lot accomplished on the car.... If I can keep my wife from making me do house projects.
      I get summer hours here at work too=) I am sure you will get everything sorted fairly quickly and easily
        I just wanna be driving the E30 right meow... Counting down the minutes till 4.
        • 3
          328ci
          Living in oshkosh, I really want to take some pictures of this car sometime
            Man what a great shot!
              Repost from the E30 tech thread - thoughts?
              To those who have installed solid trans mounts in an E30. I just finished installing my solid engine mounts and trans mounts, and took the car for a quick test drive (1989 325IS, fairly stock M20). Engine/trans vibrations are fine, throttle response is great.... but under load between 3k-5k I feel a "rumble" from the driveline. I'm not sure if it's a "trans vibrating tunnel/chassis" rumble or a "Might lose a driveshaft" rumble. Any experience with a similar noise/vibration from others? I'm well aware I'll be feeling more vibrations and such through the car, but this one immediately had me going "uh-oh".
              Also - are the OEM trans mounts a "straight through" design? When I removed my original mounts, one mount had the studs a good 1/2" or more "off alignment" from one another. Not sure if the new trans mounts "corrected" this misalignment and is causing a vibration - or if that's totally acceptable.
                The OE trans mounts are not straight through, the studs are molded into the rubber mount. There is a little bit of stud offset
                  Stupid question, but can the mounts be installed upside down or are the left and right different?
                    Maybe the OEM ones, the Condor ones are identical.
                      Alright, I'm calling the vibration "not okay" and blaming it on a driveline. I'm gonna pull the driveshaft to get balanced, and get a new guibo and CSB. Having never done either, any words of wisdom.
                      Still debating on doing before scooters or not. I can likely have parts on Wednesday, but that's cutting it alittle close to reassemble (in case I run into any issues).
                        Make sure to preload the CSB rubber surround when you bolt it in.
                          Its an easy job that can be done in an evening, just make sure you but the bolts through the right direction when putting on the guibo.
                            Clean, scrub, paint, replace..... Busy busy.
                            Headlight surrounds, wiper arms, and lower wiper motor cover thingys painted and reinstalled.
                              So pretty, nice work.
                                Latest E30 work:
                                Opened garage door to make sure it was still there.
                                ....more to come.
                                  Hey, hey, hey, hey, hey, hey............anything new on this puppy?
                                    ^ I second this statement, anything new prepped for DIV?
                                      I've been so busy with house and baby stuff,
                                      Not much to report. This winter will start all the bay work, but won't be much to report between now and then. Just driving it and enjoying it!
                                      I do need to replace the guibo and CSB soon tho, hopefully order parts this week.
                                      One from this weekend:
                                        Looked good sir Rice=) Thanks again for the pancakes
                                          Just alittle something to hold me over till snow falls and the real work begins.
