  4. E30 no start problem. Help!
14 Posts 6 Posters 180 Views 1 Watching
  • mystere30M
    mystere30M
    mystere30
    this is why 5speed swap is no bueno. :( probably some electrical crap. i wish i could help more but the neutral safety switch is what my problem was
    • AvusHatesConesA
      AvusHatesConesA
      AvusHatesCones
      I thought maybe I wired up the neutral safety switch wrong, but then it wouldn't even be cranking
      Silver Grey E46 M3
      • need4speed1299N
        need4speed1299N
        need4speed1299
        Idk what you all unplugged, but you could have mixed up the crank position with something else. Off the harness, under the circle dealio for reseting maintenance are 2 connections. Try switching them. The other one is a refernce sensor from the plug wires.
        Make sure your plug wires are hooked up in the right spots on the cap. The wire from the coil connects in the center. Also, make sure the cap is on all the way.
        Lasty, make sure nothing under the dash is unplugged.
        • camarokC
          camarokC
          camarok
          Never fear, I'll be at your house Monday evening... :)
          +1 from Nick, the plugs are interchangeable, very possible you could have swapped them, they are 2 wires plugs....
          Man, I don't even own an e3o, I should totally buy one with the knowledge I've gotten through the years...
          KEVIN
          BMW CCA # 416146
          sudo kill -KILL cupholders
          CDV Free, 545i Shifter and ///M Weighted Shift knob.
          Member of DSC Module Failure Club $$ :(
          deathwarden5 said:
          Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
          Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
          • mystere30M
            mystere30M
            mystere30
            yea from mine breaking all the time ^^^ hahahaha...aw :(
            • camarokC
              camarokC
              camarok
              That, and May's old car, and the old auto-x beast, and one or 2 more probably ha
              KEVIN
              BMW CCA # 416146
              • AvusHatesConesA
                AvusHatesConesA
                AvusHatesCones
                Hahaha thanks Kevin! I will be sure to have some beer waiting for ya! Any preference?
                Silver Grey E46 M3
                  a general rule:
                  if the problem wasnt there before you started you working,
                  you created it with whatever you did. fixing unrelated stuff will not resolve it.
                  the chance that a new problem cropped up at the same moment is slim. go back over everything you changed/unplugged etc
                  • AvusHatesConesA
                    AvusHatesConesA
                    AvusHatesCones
                    Well unfortunately I did have a few unrelated problems crop up too but I fixed those. And Kevin is the man, we got her started last night but then found out it developed a huge crack in the intake manifold so I'll be doing that tonight.
                    Silver Grey E46 M3
                    • mystere30M
                      mystere30M
                      mystere30
                      and then bought one from me :D
                      • camarokC
                        camarokC
                        camarok
                        Glad to hear it's running, never a prob! I like a good challenge!
                        KEVIN
                        BMW CCA # 416146
