  • faja92F
    faja92F
    faja92
    Hey! I havent been on for a while but I thought I'd mention, I work at a powder coating place and I'd powder coat whatever anyone desires for cheap
      I may need to take you up on that soon=)
        I got out to the shop after work today.
        I started by installing the wheel bearing snap rings with a thin layer of anti-seize so they don't seize like my last set was
        As you can see, some painting was in order.
        I started by scuffing the rust and flaking spots with a scotchbrite pad. I then masked everything off.
        I then sprayed them. I am really happy with the outcome.
        More progress will happen tomorrow afternoon
          Oh I see how it is! :P Haha
            My front sway bar is bigger than your oven lol
              Haha I know! Just messin with ya! Everything is looking good tho Earl. Keep it up!
                I did some work yesterday.
                I started by pressing my hubs in.
                First I put a very thin coat of anti-seize on the inner race of the bearing and then I tapped the hub with a mallet to get it started
                After that I used my homemade tool (a nut and bolt with misc washers) to draw the hubs in
                They went in very smooth and without too much effort.
                Then I applied a thin layer of anti-seize to the hub to prevent corrosion between the hub and rotors
                After that I installed the Adams Rotors, along with the stainless ECS rotor screws
                After that I planned to start doing the rear swaybar
                I ran out of time before I had to leave but I got the end link brackets installed
                I was looking at how to get the end links on the bar and it seemed impossible to me. The hole in the end link is half that of the bar. Supposedly dish soap is the way to go so I may try that Friday when I get back out there=)
                It is slowly but surely coming along now
                  Fridays plan was to pop the axles back in and get the sway bar installed. I got the axles in and then realized that I want to either replace them or get them looking like new. My previous paint job isn't holding up so well. I still kept them in because I planned to put the back of the car back on the ground.
                  I popped the end links on the sway bar and it was looking great
                  I then tried to struggle and install it alone and realized that the paint isn't going to hold up to what it needs to. I took the end links back off and will be getting it powder coated. Since the two things I had planned didn't work, I packed up and headed off to a friends so we could cruise to Automotion. The weekend was beautiful and it sucks to be back to work.
                    I spent all Saturday at the shop.
                    John came out and did some welding and grinding in the bay=) He did a really good job
                    I finished part of a project I have been thinking of. BMW used self tapping screws for multiple areas in the front of the car. The ones that I wanted to change over to m6x1 are the headlight mounts and the fender mounting holes. I got the easier of the two done.
                    I started off with the ugly hardware
                    I then drilled out the threads
                    Then ran an m6x1 tap through them
                    The finished product
                    I will be sorting out the fender mounting hardware next. There isn't enough material to drill and tap for those so I will have to get creative with the use of rivnuts/nut-serts/blund nuts.
                    The next thing I did was remove the seat belt mounting bars to get them powdercoated.
                    Most of the rest of the day was spent cleaning the front floors of the car. I want to look for any surface rust from salt and water soaking in the carpet during winters. The passenger side is rust free and I am now looking at the drivers side.
                    Other than that I ordered my brake pads through CaTuned and will be placing some other parts orders this week=)
                      The floor looks to be Silver,  I thought this car was Black.
                      What kind of wizardry is this?
                        10 years of storage etched the...... I got nothing.
                        WHY YOU NO DONE YET?!?!?
                          It is black=P The flash of the camera is just reflecting off of the matte black
                            Did you pop the sound deadening tar up?  I found surface rust under tar that looked perfect.  It is a moisture trap.
                              I did not pop it up. I figured that I would see any surface rust around the edges of the tar. Everything looks perfect on the passenger side and no undercoat is missing underneath so I figure it'll last as long as I am alive=)
                                Just giver!
                                  haha I know how much of a pain that stuff is to take out so I am avoiding it. There were no spills or evidence of salt on the floor itself so I think it is safe. If there was any salt or dried residue I would definitely remove it. I wasn't even planning to dig this far into the interior at this point so I figure a good cleaning and light rust search is good for now=)
                                  • 3
                                    328ci
                                    You probably have mentioned it in this thread before, but what color are you planning on painting it when its ready?
                                      It will be resprayed Schwarz II / Gloss Black again. I am trying to keep it simple and classy. I don't want it to be wild and flashy=)
                                      • 3
                                        328ci
                                        Good choice
                                          It will get sprayed.
                                          One panel at a time
