  4. E28 SETA Build
E28 SETA Build
240 Posts 16 Posters 0 Views 1 Watching
    Yeah i didn't catch it the first time either, although it is a euro spec car the car was chopped at the prop house for the movie. http://jalopnik.com/5067674/man-restores-griff-tannens-hover-bmw-from-back-to-the-future-2
      Here are the dimensions for the holding tool.  25.4mm in an inch.
      http://www.bimmerfest.com/forums/showthread.php?p=5300454
      • RamRod E28R
        RamRod E28R
        RamRod E28
        Almost everything is put back together!!! But... She will start right up and instantly die??? Any ideas?
        1988 BMW 528e - Need parts?
        1996 Mazda Miata (SOLD!!!)
        1996 BMW 325i (Donor car)
          Fuel not primed, my e30 took forever to start after draining the fuel, pull out the fuel pump relay and use a jumper wire to run it for a minute.  I think the pump only runs a few seconds and it takes forever to get the air out of the fuel rail.
            Here are some pics of the thermostat housing repair.  The nipple for the throttle body heater was corroded terribly so I drilled it out and tapped it 1/8 NPT.  If this happens to you and you want to keep the throttle body heater you can get an 1/8 NPT to 3/8" nipple fitting and thread that in.
              bfinley
              Burn out videos ?!
                We got some flyby videos last night, Mikes dad was running the camera.  It runs very well.  Pulls like a boss.
                  bfinley
                  I can't wait !
                  • RamRod E28R
                    RamRod E28R
                    RamRod E28
                    Now to feel better tomorrow (had a sinus infection from hell today, didn't even leave my apartment today :( ) get this glorious hunk of metal registered and insured and then irritate the local yokels with the e28. Can't wait to do the i stroker setup and maybe mega the squirtin and turbo this winter. All in all I am more than happy with the car now. If you have an e28 that isnt a manual, you are wasting your time!!! Also the exhaust would even impress Thor (the god of thunder)
                    • RamRod E28R
                      RamRod E28R
                      RamRod E28
                      OK finally back on here... The e28 LIVES!!! The manual swap was the best thing ive done to the car yet (besides the Menard peformance exhaust). It pulls very well for being an n/a seta manual swap car. Also i have the auto diff in it still and no complaints, its geared perfectly and it can light up the tires in the dry from a stop no probs, in the wet itll spin up the rears through second!!! I will shut up now and get you guys what you really want... PICS!!!
                      Dat sticker doe!
                      E0D2FDA2-283C-4C34-A397-FB7BB72BC376zps
                      Night shot
                      475CCF64-4479-475C-B62F-AF0AEB97CA7Czps
                      • RamRod E28R
                        RamRod E28R
                        RamRod E28
                        Heres the longer vid of the e28s first startup last one was for instagram
                        • RamRod E28R
                          RamRod E28R
                          RamRod E28
                          Im thinking about doing this for my back bumper and make a low trailer for it as well
                          http://stancewords.stanceworks.netdna-cdn.com/wp-content/uploads/2014/04/DSC7181-as-Smart-Object-1.jpg
                          • RamRod E28R
                            RamRod E28R
                            RamRod E28
                            Did some screwing around on my car yesterday
                            Found this old dizzle exhaust tip which slid right over my twin tips
                            6F25B415-1F8C-41EA-85BE-B2B83A85E2F0zps
                            Then I broke out the 2 shitty cragars that i had laying around for a test fit. What do you guys think?
                            F0D11FDF-2258-4E2F-ADB4-3D8356087DDBzps
                            66497C54-6F96-4A8C-AB35-B597966224A9zps
                            3E502F8E-040B-4EAB-A4D4-FEB429A12ADCzps
                              Exhaust tip = NO!
                              Cragars = YES!
                                bfinley
                                Oh yes to the wheels!
                                • RamRod E28R
                                  RamRod E28R
                                  RamRod E28
                                  I love the wheels and that tip came off right after that pic lol
                                    Lol at the cragers not looking horrible on a European car!
                                    I wouldn't trust this at all for towing unless he did plenty if reinforcement underneath and in the trunk. Using the shock mounts seems like a bad idea in the first place since it's such a common rust point.
                                    I'd have to look up where the oem trailer hitch gets mounted, my euro shell had one. I know it also had extra bracing in the front of the trunk between the strut towers. Guys in Europe tow small campers with these babys!
                                      You should snap a couple pics Chris, I think it could be reinforced and work pretty well, obviously not too big of a trailer though.
                                        I have pictures from the previous owner when it was installed and taken off. I'll look for them next week when I'm home.
                                          You da man!
