difference between engines for '89 325i and ix
Hey, just wondering what the actual differences are between the M20B25's in those 2 setups relating to mounting for the ix tcase?
completely different blocks, they arent interchangeable. are you trying to put an ix trans on a i or the opposite? either way, it is not bolt on, and i can only imagine it is not worth the time/money to figure it out
IX->I IS a NO GO (sorry, this happened to me...) I->IX should not be a problem
Thanks for quick resposne guys, i should have searched before i posted the thread though because there's plenty of stuff on this on here.
I believe not much is different. The oil pan and dipstick location are different.
^ SO WRONG. sorry, I found this out the hard way, I say it once and for all. IX M20's WILL NOT work in an I car!!!! It is missing a hole in the block for a pressure relief valve! I cannot be done!
Told you guys to listen to me!!!!!
It can be done and has been..... just added machine work. What it all intails is beyond me, just not worth it. Find a reqular m20
