686 Posts 32 Posters 8.9k Views 3 Watching
    162 miles on the car Saturday.... Drive quite well.
    Steering rack has some play in it, just enough to vibrate the steering wheel and be annoying, so putting that on my short list of stuff to do before Scooters.
    Current list to accomplish before Scooters:
    -Paint/Replace exterior trim pieces (vents under windshield, etc...)
    -Get windshield replaced
    - Install stereo system (replace deck, get sub/amp in, etc...)
    -Tear apart engine bay and paint/coat/remove/replace so it's more gooder looking.
    Also promised my wife I'd get re-started on finishing our basement.... So gonna be some long nights and weekends this month again!
      If the steering rack has slop in it and it is not related to tie-rods, loose mounting hardware, loose steering shaft collar nut (airbag cars only) or worn steering coupler, then you could try adjusting the gear lash in the rack by tightening the 22mm screw on the bottom of the steering shaft housing. Something to try before going for a whole new rack
        Or get z3 rack
          Excellent - I'll give it a try!
            I do have a spare steering joint with good u-joints that would be a perfect candidate for a flex disk replacement in case you find its the u-joints that are sloppy.  The steering joints pull a premuium, new or used anytime before or after race wars.
            24/7
              Poly steering coupler ordered! I'll wait to pull everything apart till it arrives.
                 Wanna measure it when you get it :)
                  Sure - looking to make a solid version?
                    Yup! I also like to have cad files on all the parts I can!
                    We are putting an extra m50 head under the rover arm tonight and will be measuring the intake and exhaust flanges, and possibly the combustion chamber as well.
                    I don't always build things just to save money or whatever, I like the experience of building it, and I often learn much more about the part by doing so.
                    Thanks for supporting my enthusiasm :)
                      I'll take some measurements when it comes and throw together a flat layout at work for ya.
                        Rowleym said:
                        Yup! I also like to have cad files on all the parts I can! We are putting an extra m50 head under the rover arm tonight and will be measuring the intake and exhaust flanges, and possibly the combustion chamber as well. I don't always build things just to save money or whatever, I like the experience of building it, and I often learn much more about the part by doing so. Thanks for supporting my enthusiasm :)
                        Which Romer arm do you guys have? They're excellent measuring devices. The thing that sucks is they're only accurate to +/- three thousandths, unless you have a newer arm=) We have the Stinger II at work
                        Sorry for the thread jack Collin. Keep up the good work=)
                          Holy crap I was told it was accurate to +/- a thou! Not sure, but I know it is a stinger!
                          My cousin said he would be willing to help me romer arm the engine bay of my car :) Not that would be cool! designing manifold on solidworks hmm....
                          Really sorry about all this thread jacking.
                            To reconcile the thread jacking - maybe we could acquire a cad file of the M20 intake (at least the lower portion of the manifold and injector bungs).
                              Car show prep at our house....
                                Not much to report on lately. Ordered a poly steering coupler from Ireland Engineering - that came in mid last week but haven't had a chance to install. Just ordered new motor mounts and trans mounts from Condor last night, hopefully those arrive soon.
                                  Trans mounts might be a bit much in the NVH department, but give em a go and let us know.
                                    I read through the R3V thread on them over the weekend and got mixed feedback. It seems a lot of people daily them, but Condor and some others don't really "suggest it". I had BFI mounts in my Jetta and loved them, hoping throttle response is similar with these.
                                    Anyone know how the UHMV mounts do over time? Are they affected by heat at all (my mounts in the mk3 were significantly more "harsh" in colder temps) and do they "break in" after a period? I'm not too worried about them, as the car isn't a daily and because Racekor.
                                      Theres no breaking in,
                                      One item of comfort is that you will have less vibration than the Jetta had right off the bat with it being an inline 6  vs non-balance shaft 4cyl.  Colder temperatures will cause them to vibrate more. The effect is exaggerated in rubber mounts since their hardness vs temperature change is much larger.
                                        I had assumed as much, either way I'm not too worried.
                                          Can't wait to see this again at Scooters=P
