  3. BMW Discussion
  4. The official WHAT ARE YOU DOING TO YOUR BMW thread.
184 Posts 40 Posters 3.4k Views 1 Watching
  • NarcosisN
    NarcosisN
    Narcosis
    Got suspension installed, visited the body shop to get some paint touched up after a winter issue, and am going to start upgrading my audio system soon.
      Change oil. Checked coolant crap. Installing hydro with earl, stew, and john
        Installing an F1 aluminum flywheel and Sachs clutch in a late e36 today.  I also got a 75/25 gas bottle for my birthday so I can weld like a boss now.
          I will be pressing my hubs into my rear bearings today=) After that I will be sorting a bunch of other tidbits in the rear
            I'm going bald waiting for the unknown. Then after that I'm waiting some more.
              im converting fuel into clutch dust
                I am finally getting back into working on it after a horrible winter and spending my time moving.
                  Pressed in my hubs and installed my Adams Rotors yesterday
                    looks so good! Im hoping you replaced all the parkbrake stuff while you were in there.
                      Some butt nugget before me tore absolutely all of it out so I have nothing. I am trying to think of a way to link my handbrake up to a cylinder to have a hydraulic parking brake.
                        It wouldn't be too difficult to put a hydraulic parking brake in.  Wilwood makes a hydraulic hand brake kit that splices into your rear line so the brakes work normally until you pull the handbrake and it locks on the disc.
                          Problem is, pressure will bleed off.
                            Carry blocks...
                              I always put the car in gear and never had an issue with it moving. That's not goo on the trans though. We all have to remember though, I can air out and use my frame rails as my brake=)
                                I haven't had a parking brake since I bought my car and have only put it in gear without issue.  Fixing my parking brake is on my to-do list somewhere...
                                I vote this!
                                  Eventually.
                                  Johns knife-dro has locks on it
                                  I asked him if he looses pressure when he parks. He says he does not.
                                  Discuss
                                  The lock is the little blue thing behind the handle
                                    Johns hand will bleed off
                                    Tell that boy to log pressure vs. time, then come back and tell me what a bish I am.
                                    ...bish
                                    jk, but with all the bolts and knobs earl has polished, would he really want to risk losing his car while parked on the streets of san francisco? Especially if its on a hill that requires holding the foot brake while applying a heavy dose of hand brake.
                                      Get a pass through setup. Do what we did to my car. But instead of getting a handle with it. Just set it up with your stock ebrake lever.
                                        Basically something like this.
                                        (Had trouble finding a good pic of what I'm talking about)
                                        Or
                                        Kind of like the pic, except Retain stock lever and stock look. Just splice into your lines. Good news is that you already Are practiced up in bleeding brakes :)
                                          As always... Top Gear has your answer.
