  4. custom coilovers = lol
37 Posts 9 Posters 634 Views 1 Watching
  • RamRod E28R
    RamRod E28R
    RamRod E28
    How did the sprockets look? Have you run the engine for a while? When i fire up my m50 after storage it rattles badly and you need to hold the rpms around 3k for a minute or two
    This doesn't seem normal mr Menard I think it's time for u to order a vanos rebuild kit and I'm thinking about doing mine when I service my cooling system on the e46.
    1988 BMW 528e - Need parts?
    1996 Mazda Miata (SOLD!!!)
    1996 BMW 325i (Donor car)
      Derflaminflitzer
      all the guides are brand new the sprockets look good the bearings in the idler gear look good everything looks good. I'm just not sure what's causing that rattling. It sounds like the chain. Maybe the one lifter that failed causing the knock has a blocked oil passage leading to it partially starving that lifter of oil until it fails. I'm not positive though I'm just going to run it and see what happens. If it does it again then I know there is a crazy issue.
        The oil drains out of the lifters after sitting, it's not the vanos.  It can sit for a couple weeks with no problem, it's just when it sits for several months over winter.  The vq30 in our Maxima rattles for a couple seconds if you leave it for a week...
          Derflaminflitzer
          20140417225850zpshyhbwsgl.jpg here we go again
            Derflaminflitzer
            Im getting pretty good with the old m42 deconstruction haha took me about four hours to get this one out by myself
              Good Job=) Hopefully third time is the charm
                Derflaminflitzer
                I should be able to tell you if that is true tomorrow :) maybe even tonight. Depends on how much I hustle.
                  Derflaminflitzer
                  You are more than welcome to come play with me earl :)
                    Derflaminflitzer
                    Shes back on the road! Running better than ever too. Thanks to Snap lending me that clutch tool :) byno means would I call myself a mechanic but I do know my way around an m42 now... that's for sure. Besides the physical aspect of using the picker to pull the motor and then placing the new one back in, I did all that shit by myself. Working on it for two solid nights and some random bits here and there in between. Not bad for a rookie. And by the way, if anyone ever wants to swap an e36 m42 into an e30 you have to swap way more shit than the internet says you do lol
                      This is good news!
                        Still can't believe you pulled out the motor and didn't m50 swap lol.
                          Derflaminflitzer
                          If you would have bought me the trans, drive shaft, diff, swap pan, booster and all the other piddly shit that goes along with the swap I would have. For $400 I can drive my car again. Ill take it. If I swap the car for a 24 valve or anything other than stock motor I would rather do something a lot cooler than an m50. My theory is...it would suck really bad to swap my car for performance gains and still get shit on by an STI or some stupid shit of the sort lol
                            There you go. Keep it slow until you can afford to go REAL fast :)
                            • J
                              J
                              joebar94
                              Good to hear:)
