E28 SETA Build
One only needs to consult with the experts on Yahoo Answers to gain a clear understanding of which is better, carbs or EFI
https://answers.yahoo.com/question/index?qid=20080506063936AA8P8CX
Dave87gn: "fuel injection is way better,"
Pedro S: "carbs r cheap and crude...Fi is better for mileage, engine life but complex and expensive...."
FrdFnatic: "if you flip ur car fuel injection will keep it running. carbs wont. so if u plan on flipping ur car i would go with carb"
OK.. so a little status update on the seta swap e28 it may not look like much but just been doing all the piddly odds and ends on the car. I also did spend some time with a can of brakleen in the bay cleaning up any grease or dirt from not seeing the day of light in over 30 years. So without further ado some more pictures.
All this work to add one more pedal!!!
Got the steering column back in. which for some reason was a bigger bitch to do that I remember lol
Got the auto shifter out and that was easier said than done you have to almost completely remove the center stack to get its fat ass out of there.
Now just need to order parts and BAM!!! engine and trans are going back in and I will be posting burnout vids as soon as any of the bugs are sorted out.
Yes!!!!
Ride is the same and it is a bit more stable in the wind but way more confident in the corners and only lost a tiny bit of fuel economy but this may be because the old g forces on the wheels are worn very unevenly causing more rolling resistanxe
The wider the tire the worse fuel economy, maybe put 225's on them instead of 235's when you replace the tires. Also funny that that the pics are in my parents driveway. Did the hub bore match up? I have the 4th hub ring adapter at my house if they were the right ones.
Backstory, my dad bought these wheels to put on his 06 Maxima because the craigslist post said they were 17's and he didn't even look. Turns out they are 18x7.5. So his good tires that he took off of his stock wheels when he had Blizzaks put on didn't fit. They are 5zigen pro racer wheels, pretty legit in the tuner world apparently. Seen alot on Subaru's, Civic SI's, s2k's, and of course, Nissan vans.
Back to bmws!!!
OK ordered what i think is all of the parts that i need to get the manual and super eta swap done last night off pelican parts! I love ordering stuff and will love it even more if my e28 would just put itself back together when the parts show up lol
my parts wont show up till next tuesday and i ordered monday!!!! grrr!!!! wtf pelican???!!!
AANNNDD now my e46 trunk light dash indicator was on even with the trunk perfectly closed and also the key the handle and the trunk release button on the dash arent working lovely.... I will have to do some digging. Most likely where the wires flex when the trunk opens and closes I bet a break is in there...
I have had to repair my e36 harness where it bends for the trunk to open as well. Use some 3M rubber splicing tape over the whole thing once you repair the wires, it seals to itself and stretches very tight. I use it at work for insulating lug/bolted motor wiring connections, but you can find it at at any hardware store.
Ok... Finally got my parts from Pelican after ordering almost 2 weeks ago... not too happy about that and they didnt even send me a sticker
and I realized that I ordered the wrong size copper lock nuts for my exhaust studs so gonna see what options I have.And found out why my trunk would only open with the key in the tumbler and why the trunk open light would stay on with it shut...
That was a fun one to get to i had to almost cut the entire boot in half to get to it.
Some e28 getting put back together porn coming your way soon!!!
As a matter of fact it does! You would not believe the amount of dirty looks I get! It's actually worse than the no fat chicks sticker with the whale below it
