  4. New Daily: 1992 E34 525i 5spd
97 Posts 15 Posters 1.6k Views 1 Watching
    Same as what our 11%-er said, I havent heard of the BMW cast manifolds being known to  crack.
    I wouldn't run headers unless they were long-tube but that usually ends up being a PITA.
    I guess I would run cheap shorty headers if it ended up being cheaper than a replacement cast manifold and you didnt mind possibly sacrificing some low end power.
      Looking at the pic on their site it appears that its more like a "slip on" to your cat section, it has its own downpipes which have a two bolt flange from header to DP rather than OEM 3 bolt.  Looks like you install then cut your cat section and clamp or weld the new downpipes on.  Not a bad setup, and I may go with this in the future, just not a direct bolt on.
        You can also get the m/s52 tubular header type manifolds for cheap, which are a direct bolt on to your downpipe and look much cooler, not sure if they flow better though.  This is what I am doing for now.
          +1 on the s52 manifolds.
            Do you guys have a link to those?
              They are stock headers from 96-99 m3.
                oh gotcha....hmm
                  m52 and s52 headers are identical.
                    +1
                    Just break out the heat&hammer
                      Got this bad gurl detailed yesterday
                      Mats before and after
                      Some of my ignition coils must be cracked because the moisture from washing the bay caused a bad misfire. Hopefully I can find a coil today to solve that issue=)
                      • RamRod E28R
                        RamRod E28R
                        RamRod E28
                        A clean car that doesn't run is as bad as a dirty car that runs great
                        1988 BMW 528e - Need parts?
                        1996 Mazda Miata (SOLD!!!)
                        1996 BMW 325i (Donor car)
                          It runs and drives. It just misfires now. John is coming to save the day
                            Good 'ol Concours detail department, I miss having my car showroom clean haha. Looks like it turned out great!
                              If you wash non running cars there. They automatically turn into running cars.
                                Looks like it worked opposite on Earl's coil packs...
                                  The magic must have left with Rampelsauce
                                  #neverforget
                                    John came over with two coils.
                                    When I took the engine cover off you could see already that the coil for cylinder one had the connector cracking off. When I pulled it out and looked in the plug hole there was a bunch of water. We proceeded to pull the coils to check for more water. The first three holes were pretty full. The last three didnt seem to get wet. I put Johns coil in for cylinder one and put it all back together and it ran awesome.
                                    We then took it on a run through the woods and it was running great. After getting out of the woods it started to have a slight misfire again and then idled bad. We stopped at our destination but it ended up being closed.
                                    I let John drive to our next destination. It slowly seemed like the misfire went away. I let John drive it back to my house then and it didnt misfire the whole way.
                                    We worked on Johns car and then watched some Trailer Park Boys. Right before John left we took it for a ride and the misfire was gone. I am thinking one of the plugs was all funky. I might change them since I drove 40 minutes home with one cylinder not firing.
                                      Sounds like you are on the right track, could also be one of the boots that goes from the plug to the coil is messed up.  Try running it in the dark and look for stray sparking anywhere.
                                        One coil has a boot that is cracking and chipping at the bottom. That would cause a misfire?
                                          Definitely!  That's a common fail on these.  You can pick boots up fairly cheap.  Any oil in the spark plug hole?
