  4. New member something " a little" different
76 Posts 15 Posters 1.4k Views 1 Watching
  • J
    J
    JustTouge
    Chadley said:
    You probably need new suspension bushings. E36 bushings arent known for lasting a long time (set aside 500 bucks for FCABs, control arms, end links, diff carrier bushings, RSMs, RCABs, diff bushings, etc.)
    M50>M20
    You need new headlights and some Euro clear corners
    Most likely bad connections on the back of the cluster, pull and check (two screws at the top and some wiggling to get it out)
    Supercharger noise is the belt tensioner bearing going. 30 bucks from pelican parts
    I have window motors and switches if you need em. E36 interiors arent known for interior greatness either
    Hows your heat? Im guessing you just have green coolant and not BMW Blue? Obvious could be heater core, but could also be leaking pipes. Trust me, this one isnt fun.
    Im the resident E36 guru. Where are you located? I'm in waukesha, just west of Milwaukee. If you're near, lemme know
    Awesome information, thanks. I figured that the wheel hop, and overall suspension sloppyness might be due to bad bushings throughout the whole car.
    I like the idea of headlights with clear corners. I have looked into the DJ auto lights on DDM, I will order a set eventually. Tailights also need to go, not 100% sure what I am going to replace them with yet. Altezza's yo! ( I keeeed I keeed).
    How much you want for the window motors/switches?
    Heat works great, I'm worried the blower motor is going though. Heat only works on low and high, I believe there is some sort of relay I can replace near my gas pedal to fix this, but if I read correctly online, it will most likely break again becuase my blower motor is going. I can't think of whats that called right now...
    Coolant is Green.... Should I flush that out?
    I'm in Oshkosh WI, but I am in Milwaukee visiting friends from time to time.
    • C
      C
      Chadley
      Tony. Go die.
      +1 to the DDM DJ auto lights. I rock those too and love em (although if I remember correctly DDM is trying to stop selling bmw stuffs, so you might wanna get em while they last. Also, DDM has the worst customer service in the world)
      Clear corners vs amber is a personal taste thing, I'm gonna get clears because of my frenched fogs, and I'm bored of the blacked out look.
      Make sure that your cooling system is in good shape. As in, if you dont know when its been replaced, make that in the top 3 of to do. One overheat kills M5x engines. ECStuning.com has an overhaul kit for 220 bucks which has everything except the radiator and an extra gallon of coolant. I got my kit from them and so far, so good!
      What color is the bottom of your switch? I have green bottom switches, so you'd need those in order for the switches to work (BMW used like 4 different window switches in E36s). I'll get it all together and quote you a price
      I see you're OBD1, so you dont have a FSU (unless swapped the digital climate control panel into your car). I'd check out the heater control valves as well, those are under the intake mani, kind of a PITA to get but not too expensive/hard.
      If you wanted to go back to blue, I'd wait till you have the new cooling system parts. I did that, and have been running blue ever since. The whole debate is green coolant conducts electricity and causes hydroelectric charges to go through the cooling ports in the engine, which wears on aluminum parts. Some people say only BMW blue (G-05 formula I think) will work, others think its a ploy for more money, and some dont care. Its your call. Personally, I'd go with BMW blue though
      Let me know if you're ever around. Im always up for a photoshoot or wrench day
      • J
        J
        JustTouge
        Again, thanks for the awesome info.
        I'll look into ordering headlights soon, but I think the cooling system is a bit more important.
        Not sure on what color switch I have, I can look later, its pouring out right now.
        The car developed a issue over the past few days, but today it seems worse. The car clunks up front while hitting certain bumps it seems. At first I thought it was ball joints or bushings, it wasn't that big of an issue. The clunk was quiet. Today though it seems worse, clunks alot while turning right, but much less clunking while turning left if any. Its a pretty loud clunk now, I'm concerned. It seems to be coming from the middle of the car to me, could my guibo bolts have came loose? I wish I had a nice warm lighted stocked with tools garage to use.
        • C
          C
          Chadley
          Jack car up and feel the suspension parts (you know, check for play and such). It sounds like the nut on the top of your strut has come loose, allowing the whole strut to move up and down inside the mounting plate on the top of the housing. Pop the covers off and see. This has happened to me numerous times and drives me bonkers
          • J
            J
            JustTouge
            Are you talking about the 3 bolts on the top, in the engine bay? Mine seem nice and tight...
            Spent 4 hours washing, waxing, and cleaning it. Helped alot, but some areas still look like they were buffed with a steel wool pad. Here are some pictures.....
            Posted Image
            11 by Touge Photo, on Flickr
            Posted Image
            10 by Touge Photo, on Flickr
            Posted Image
            9 by Touge Photo, on Flickr
            Also ordered a set of Rokkors today, Hoping to diagnose the odd clunk while I install them later this week. Also might have a line on some 7 series wheels too.
              You talkin some style 5's? I've got a few wheel choices that I'm looking at...and all would be imported=O
              • J
                J
                JustTouge
                No they are not style 5's, I wish. They look kinda similar, they are a 16x8 BBS wheel. A guy offered to trade them in my ad listing my Kosei's for sale. Seen here... http://hondamarketplace.com/showthread.php?t=2996367 He posted some pictures in there...
                318t'ILL lets see some pictures of your car!
                  Those look pretty nice=P And mine isn't anything special at the moment but here is a recent shot=)
                  Posted Image
                  • J
                    J
                    JustTouge
                    Your car is slammed. Damn. Looks good.
                    Why do certain cars have front plate mounts like molded into the bumper, but some like yours don't have the spot for the front plate. Looks much better.
                      You can buy plate deletes=P I actually took my OEM molded plate strip and cut it down to be the same width as the rest of the trim. I lightly sanded it and then dyed it with trim black and have my own ghetto plate delete;)
                      And it is faily low=P The bottom of the front fender is about a keys length off the ground. The frame railgs are faily close and I cannot go over even the slightest speedbumps=)
                      My wheels are sunk so bad that it embarrases me=( I need to figure out what wheels I want to run and I have to get my other sets of wheels sold to be able to buy more wheels=) lol
                      • J
                        J
                        JustTouge
                        Thanks for the tip, I will do this tomorrow if I find the time. I had thought that peice was molded into the bumper until now.
                        A set of style 5's would look tits magee on your car.
                        I hope that those wheels from hondamarketplace look decent oon my car after I lower it.
                          Those wheels will look perty good on your car=P And I just noticed this, but did the PO put one piece headlights on your car? I absolutely hate those=P lol
                          And a set of style 5's or BBS RS would look wonderful on my car, but sadly they're too played out and I like being original=) lol
                            Posted Image
                            BTW here is what I started with. The day I got my car
                            Posted Image
                            • J
                              J
                              JustTouge
                              Hope they look okay, I have been trying to find a similar set online so I know how much they are worth. I am trading the guy my kosei's that I listed for 400$ (which is pretty cheap for the wheels). I just want to make sure I am getting a good deal.
                              Yes I have these fancy one piece headlights on my car, they NEED to go. Look like balls, and one side doesn't have working Halo's. Next paycheck I will order new headlights and taillights(not sure what tails I want though).
                              I agree with the being unique statement, I try to add a little personal flare to my cars. I really want to pick these wheels up, but its a bit of a drive for me and I don't exactly have the funds for them. I should put that money into some suspension maitenace. I think you will like these.... Something cheap and different.
                              http://lacrosse.craigslist.org/pts/2633157115.html
                                wow that is stupid cheap=O I would go right now and say screw it for work to get those=P lol I'd use them as winter wheels and everyone would hate me for it though. lol But have you seen sawblades on an e36? They look pretty good=P
                                Posted Image
                                • J
                                  J
                                  JustTouge
                                  Do it! Buy them for winter and sell them to me come spring! I talked to the guy, he needs them gone he is moving soon.
                                  Also, was that just bumper trim spray paint you used to spay the lower section of your front bumper? Looks great.
                                    Yeah I used the sponge applicator type trim black and did =P lol It actually looks good up close too if you take your time and tape off all surrounding paint. I have a different bumper that I have to finish prepping and painting to put on=) A non m bumper, but a different style. And idk how I would pick them up...lol I don't wanna drive all the way out there=)
                                    • J
                                      J
                                      JustTouge
                                      Do you have camber plates for your car? Hows your alignment?
                                      Hopefully the coils will come today. I plan on driving to get those wheels this weekend as well, things are looking good.
                                      On a side note, I drove my car in the slush/snow the other day to see how the E36 would handle it. The car had a suprisingly decent amount of traction. Under full throttle it would slide most of the time, however.... This car really really tends to understeer at times. It sucks, my handbrake doesn't work well enough to compensate for it. I am worried that this winter I am going to be hitting everything from just going straight through corners. I hope the new suspension, and a alignment will fix this.
                                      • T
                                        T
                                        ten2doyle102
                                        My 330 was exactly the opposite. I am surprised that you're understeering. What do you have for tires??
                                        E30 by ten2doyle102, on Flickr
                                        2000 Audi S4 2.7TT, 1991 318is 1.8L
                                        Represntin' da A-Town foo's
                                        • J
                                          J
                                          JustTouge
                                          BF goodrich Touring T/A's Decent-ish tread on all of them, however I noticed that the fronts have some abnormal wear on the insides.... This car needs an alignment. I will get one as soon as the coils are on.
                                          I had mentioned last week that the car has developed a mystery clunk. Its getting louder I think, its now developed into a serious issue. Anytime I turn my wheel right while moving it makes a clunking/ knocking noise. The noise increases with speed. It reminds me of when I axle boot rips on a FWD car kinda. To me it sounds like its coming from the passenger side, or maybe the middle of the car... I am 99% its up front. I can feel it when it happens. It happens when slightly turning, all the way to full lock to the right. Anyone have any insight?
                                          Also look what came about 10 mins ago.
                                          Posted Image
                                          12 by Touge Photo, on Flickr
