  4. Savin Big Money Project Thread
should just dri
178 Posts 23 Posters 3.3k Views 3 Watching
    I will be using the original m50 sprocket.
    Rear sub frame mount reinforcements are installed, Started on RTAB pocket reinforcements.  The undercoating has been a nightmare.  Mike came over to help some and it is too slow with the current method.  I am going to make a Harbor Freight run and get a sandblaster to give that a try, even if it doesn't work it will be handy to have for other projects.  Tried zip strip and it doesn't even soften it, not sure what else to do.
    Moral of the story, just buy a car from the south.
    You nailed it.
    Less time messing around with rust repair and stubborn/broken bolts, more time improving things, more time enjoying the car.
    • RamRod E28R
      RamRod E28R
      RamRod E28
      Yeah but getting a car from the south means u have to trust photos and the cost of getting it too
      1988 BMW 528e - Need parts?
      1996 Mazda Miata (SOLD!!!)
      1996 BMW 325i (Donor car)
        I bought my current 528e based off two crappy cell phone pics, so it was a good surprise to see how good a shape it was when I picked it up! While its nice for suspension work, body work has to be done on almost any car this age. Also fixing things yourself means you know your car better and won't have any surprises down the road.
          My car is a Florida car (Not the salt spray part) and it is clean as a whistle underneath, the only problem is that anything made of plastic must be handled with more care than an ancient manuscript...
          On a more relevant note, can't wait to see the progress!
            I will know every nut and bolt on this thing after I get done with this.
            All reinforcements welded in.  Pics tomorrow.
              Here we go, First was out having some fun driving the cruiser.
              Here is the pile of undercoating so far.
              Rear subframe reinforcements.
              Rear trailing arm pockets.
              Then I made an air dryer for sandblasting.  Here is what the inside looks like.
              Finished.  When you want dry air, connect the air so it goes through, and fill the PVC tube with ice.  Air temp drops, moisture condenses and stays in the bottom of the loop, then just drain periodically from the copper line.  It will be mounted to the wall and then can be drained of water from the ice melting with the PVC valve at the bottom into a bucket.  After going through this it will go into a filter as well.
              Then I cleaned up the garage, it was getting pretty bad.  Messy garage = poor productivity.
              My piles of parts are kinda scary so close to spring...
              And a few parts that were powder coated.  Kawasaki black.
              Got a sandblaster from HF so next week I will try to get the shell into the driveway and start blasting.
              And my new awesome garbage can.
                How are you gonna move the car out of the garage? I've always been curious if 4 1000# mover dollies ($20 each at HF) could serve as car dollies for a bare shell.
                  bfinley
                  Looking forward to see how the blasting goes!
                  Let me know when you want help putting all those parts back in, 3 of us could get her back together in a weekend easy
                    It works, I have used them in the past, and my civic shell is setting on three of the wooden ones at the moment!  :mellow:
                      BTW that air dryer is brilliant!
                        This is the plan, as long as I get it down low before moving it shouldn't be a problem, FYI if you have the drivetrain out of an e36 and have the jackstands on the factory pads you can lift the front end by yourself.
                        I will probably be on hold for a little bit, helping Mike with his e28 on Tuesday and then I might get the e30 home and start the trans swap in the driveway.  I am going to be working 5 tens a week at work from April until July at least so that sucks for BMW productivity but OT is nice.
                        Thanks!  I hope it works.  I think by using the 3/4" pipe the air will slow down enough to cool effectively.  It is also pretty compact which is necessary in my one car garage.
                        • RamRod E28R
                          RamRod E28R
                          RamRod E28
                          I bet u Ben and I could get ur e36 pretty far in a weekend. You gotta get her done soon cause the spring in spring green meet is almost upon us
                            bfinley
                            True story, course days notice and I'll clear a weekend. Plus I need a BMW ride to the meet since mine is on almost as many pieces as the e36
                            • RamRod E28R
                              RamRod E28R
                              RamRod E28
                              You may be able to get a ride in the e28 at the rate that thing is getting done!
                                I will be cruising the e30 to the meet!
                                Today the interior comes out, and going to build a cart sorta thing to move the shell around.
                                Got the driver seat out, they are ridiculously heavy!
                                  bfinley
                                  VERT! Riding in style. Are there airbags in the seat ?
                                    No airbags in these ones, but they are power/heated.  Probably close to 50 pounds each.
                                      bfinley
                                      Yikes
                                        Dash and carpet out, floor looks ok from the inside.  Lots of sticky residue under the carpet, looks to be spilt soda...
                                          bfinley
                                          Gross, does it have the black tar layer like mine did ?
