  3. BMW Discussion
  4. The official WHAT ARE YOU DOING TO YOUR BMW thread.
184 Posts 40 Posters 3.4k Views 1 Watching
    Obviously no one has been doing anything with their cars=)
    • mkoeppM
      mkoeppM
      mkoepp
      I painted my front bumper cover, repaired PO's wiring up front (I am finding crap connections all over the car and am repairing them one at a time).
      I also put my new sticker on :)
      I have a good used fuse box to replace this
      This kind of scares me. I am told it is not all that bad....we shall see....
        Looking good=) I like having a thread like this around. Glad I dug it up from the grave.
        It is nice to see what things everyone is up to.
        • mkoeppM
          mkoeppM
          mkoepp
          I cleaned up my valve cover (it used to be blue  :confused: ) and replaced some vacuum lines. I was going to adjust my valves again but they all check out good :cool: . I adjusted my TPS again...it has been giving me problems (3x adjusting). I just got my hands on a replacement but have yet to install it.
            Is your head yellow?
            • mkoeppM
              mkoeppM
              mkoepp
              Just the upper timing cover and parts of intake. It is a donor motor and PO did not clean anything before install. It looked really cool with a blue valve cover  :huh:
                Q: What am I doing to my car?
                A: Neglecting it.
                • AvusHatesConesA
                  AvusHatesConesA
                  AvusHatesCones
                  On the E46 I have a bunch of parts that I'm waiting for a weekend day to break 35 degrees in order to instal. So far I have, AKG 95A poly FCABS,
                  AKG 95A poly RTABS,    AKG 75D poly steering coupler,    UUC blue isolated transmission mounts,  replacement control arms,   my custom Coby Wheel alcantarra steering wheel,  and a 1x1 weave CSL rear diffuser.
                  The E36 is getting a whole bunch of AKG 75D poly bushings, the 75D steering coupler, an all aluminum radiator, and Dunlop ZII tires, and possibly reworking the exhaust once again because it is unholy loud still.
                  This winter just need to friggen end so I can get to work
                  Silver Grey E46 M3
                    Let us know how the steering coupler is. I have been thinking about getting one.
                    • AvusHatesConesA
                      AvusHatesConesA
                      AvusHatesCones
                      Will do, I'm pretty excited to see how it feels! Especially because the factory one is on its way out in both cars.
                      Silver Grey E46 M3
                        My steering coupler is on it's way if not gone already as well.  I'm interested to hear how the new one is.
                        • AvusHatesConesA
                          AvusHatesConesA
                          AvusHatesCones
                          Well, I'll see what I can do about getting it done this weekend to clue you guys in on the result.
                          Silver Grey E46 M3
                            What Im doing to my car... hmm....
                            From this:
                            189926110201468574788329546897395o.jp
                            To this:
                            Im coupe swapping the cab and doing a small tail/euro bumper conversion.  Also M20B23 motor swap.  Also a pedal delete, which then I shall reverse.
                            This is what Im planning at least.
                            • jockhater2J
                              jockhater2J
                              jockhater2
                              Once spring/summer hits. I gotta put my motor back in. then finish the stereo I am working on. 2 alternators, 3 batteries, 6 runs of 1/0 ga. 2 12"s on 6500watts RMS. Zed audio 6 channel for the front stage and a Pioneer P99RS HU to control it all.
                                Have some parts stacking up. If only spring would come around one of these months...
                                  Is that how most of you guys do it? Just buy parts all winter and then work on your car come spring? Man it sucks not having a heated shop. I just end up working at the machine shop on my cars... but there is only so much you can do.
                                    Planned on doing some work on my e36 this winter, just haven't had much free time. The cold doesn't help much either! Got some goodies for my touring, just waiting to pull it out of my storage once it's nice out. That ones getting a bit of a facelift...
                                      I need to get a bigger inner diameter wastegate vacuum hose.
                                        -4 I presume?
                                          -4 I presume?
                                          I think that's right. I just need 1/4 inch ID instead of the 1/16 that's in there now.
