  4. '88 E30
'88 E30
savebigmoney
    DrLeadFoot said:
    Love it!
    bringing back old memories!!
      It totally does.
        So, Jake (StewCrew) and I got to thinking.
        I dont have ebrake cables in my car.
        So instead of replacing them, we figured....why not put a hydro in?
        After some deliberation. I ordered an ASD hydro 5/8 pass through set up.
        The pass through setup allows using the existing lines in the car (dont have to run another reservoir or a dual caliper setup)
        So we met up on a Thursday and he made some magic happen while I made sure the car didnt start on fire.
        First we outlined the bottom of the hydro to cut a plate to that size.
        here is Jake doing that. (fire extinguisher for false sense of security)
        The plate bolted directly to the bottom of the hydro...
        Then we sort of guessed the size of a second plate to cut.
        It was completely random and it worked.
        Then jake used his welding skills to weld the two plates in a 45 degree angle
        he then tacked the two washers onto the bracket as well...
        (This is the top)
        and bottom (sorry about the funky angles)
        so all bolted up to the hydro...this is how it looks
        and another angle
        So the carpet was already cut up from the manual swap many moons ago, so i didnt feel bad about making more "surgical" incisions  :rolleyes:
        Just got enough peeled back so Jake could sand the paint off and make some welds
        While he was doing his thing I cut up the console to make some room
        I am going to wire the window kill switch thing together so i can loose that switch and will probably end up relocation the passenger window button to the drivers side.
        I dont really have any pictures of the "install" but it went something like this.
        So after playing smokey the bear when jake was welding everything up...this is what we were left with. (I also had to cut the ebrake console up - it will need to get cut up some more once the lines are routed so please ignore the hack job)
        Needless to say I am very excited to get the lines ran and everything buttoned up!!
        I want to eventually make some sort of "dust boot" or shift boot type thing to sort of block off the now exposed area where i had to cut up the console
        There is the perfect amount of room to get into 5th without destroying your knuckles and it is very easy to pull (not a funky angle)
        Jake picked up all the hardware we need to eventually run the lines (except for the ever elusive 7/16-20 that no one carries) so it's just a matter of finding time to get this thing finished!
        All set on the spares too :D (4 wheels&tires will be made into clouds)
        • StewCrewS
          StewCrewS
          StewCrew
          That fire extinguisher is a lie. Things been empty for months.
            I admire your ability to do simple fixes with race car mods
              Still doesn't have a parking brake :P
                just a "pull for fun" lever
                parking on flat areas has consumed my life
                  I hope someone nice got you black carpet for Valentine's day. Take that how you will...
                    Of all the things to notice in the car..... the carpet color.... haha.
                    • johnprusinskiJ
                      johnprusinskiJ
                      johnprusinski
                      I have that fitting for you. just let me know when you want it.
                        I love you john. Whenever works
                          So yeah.
                          It's done
                            Does it work well? Plenty of drift lubricant outside.
                            When does the turbo build start
                              It does work pretty well.
                              And yes there is a lot of rain out there.
                              But I also don't want to wad my car up in downtown Milwaukee haha
                              Turbo build? I just plan on living vicariously through all of the turbo builds on here.
                                now its everyone else's turn for burnouts/donuts
                                this was done on a closed country road in the middle of nowhere (on tires + wheels that aren't mine)
                                https://vimeo.com/99444032
                                  now its everyone else's turn for burnouts/donuts this was done on a closed country road in the middle of nowhere (on tires + wheels that aren't mine) https://vimeo.com/99444032
                                  All we have is a turbo oil feed fitting, and then I shall challenge you to a burnout :) Hopefully today or tomorrow!
                                  The car starts first crank though. which is great.
                                    Braaaaap
                                      I miss that exhaust note!!  BURN BABY BURN!
                                        Stretched tires must burn!!
                                          Damn kaiser now i cant shit talk you anymore until i do a better burnout
