AN fittings, who is using what?
New power steering lines are $$$ new, when I needed some for my Z3 rack swap I found some used for cheap, used new copper washers and I have no leaks.
I'd be interested to know if you find some Metric to AN conversion fittings. I haven't really looked for any yet but I will be using them for my new oil cooler setup.
Summit has a metric ton of them(pun intended). I found 14x1.5mm and 16x1.5mm, both to -8 which are what I need to put where the banjo bolts used to be. Looks like I will probably spend about the same amount but should have a superior product which is ok to me. 10ft Aeroquip -8 hose, 4Aeroquip hose ends, and metric fittings puts me at $180 from summit. There is much cheaper hose, but IMO you get what you pay for, I have used Aeroquip stuff at work in an industrial application.
http://www.anfittingsdirect.com/
I got all my fittings from them. Cheap and fast. As well as my ptfe lines.
What areas are you using them for? I'm not sure about for the power steering, says good to 500psi or 800psi with crimp fittings. No problem for oil cooler but pressure from PS pump is right around there or higher. Looks like they have some good stuff.
methanol/ethanol lines.
Excellent, thanks.
Yea sorry no help on the lines, just a good place to buy them!
I know you can get any custom hose or line made while you wait at Hyquip. Dont know much about prices tho. I have picked up a few fittings from them here and there. They are located in Butler, Waukesha and Madison. Just an idea.
