  3. BMW Discussion
  4. What did Laishes trade his E30 for?
39 Posts 7 Posters 754 Views 1 Watching
    e36
    • L
      L
      Laishes
      Rowleym said:
      e36
      nope! By the way your sig is too perfect.
      • L
        L
        Laishes
        another hint:
          E28 with a b35?
            That is an e34. I can tell by the mirror. Not sure what engine though. M52 swap?
            • L
              L
              Laishes
              Getting there! But no on the m52 swap.
              • L
                L
                Laishes
                E28 with a b35?
                Negative... somewhat...
                • L
                  L
                  Laishes
                  hint: This particular E34 as far as I know did not come factory with the engine it has in it.
                  What has been correctly guessed thus far is that it is an E34!
                  Now you guys have a page and a little to guess what engine it has swapped into it and what model the original E34 was from the factory.
                    1/1.5/2jz
                    • L
                      L
                      Laishes
                      Brian. said:
                      1/1.5/2jz
                      It's a bimmer engine although I do love the JZs.
                        s5x
                        • L
                          L
                          Laishes
                          Brian. said:
                          s5x
                          Negatory! This engine is actually pretty unique for this particular model E34
                          It's counter-intuitive to think about when thinking of a "swap" but only due to the E34 its in.
                          • L
                            L
                            Laishes
                            Thus far:
                            It is an E34 - What model (from the factory) hasn't been determined by you guys just yet.
                            It does not have an:
                            M5x swap
                            S5x swap
                            1/1.5/2JZ swap
                            This is relatively uncommon that's why this thread was started! If it had a typical engine swap I wouldn't of started this thread
                            Comon guys I'm losing faith in you all!
                            Earl gets a point for correctly guessing the fact that it is an E34!
                            Way to go Earl!
                            • L
                              L
                              Laishes
                              Hint:
                              I know it's blurry but its the best I can do without going out to the cold
                              Not sure if it helps...
                                325i
                                Twin turbo S62
                                  Wagon!
                                  • L
                                    L
                                    Laishes
                                    REKIII said:
                                    Wagon!
                                    YES!!!
                                      I'm gonna build an e34 wagon with a big turbo m30 in it some day!! Mad jealous. Love e34 wagons. I've been looking forever for a manual one around here.
                                      • L
                                        L
                                        Laishes
                                        It is an E34 Wagon with a _____ swap?
                                        • L
                                          L
                                          Laishes
                                          Comon guys!!
