  3. BMW Discussion
  4. Camera shutter style ITB
18 Posts 6 Posters 221 Views 1 Watching
  • TehRaydarloverT
    TehRaydarloverT
    TehRaydarlover
    Yeah I did the model. Interesting idea, not sure how the rubber would like being twisted repeatedly like that, it would be cool to see it in action though.
    Here is v2, trying to make it more compact:
    http://www.youtube.com/watch?v=xjSNiTF_u-k&feature=youtu.be
    Just realized I posted this in the BMW discussion instead of technical... move it if you desire
      Neat concept, but the pecision on the plates would be cost prohibitive, also getting that rotation with equal force would be difficult.
      Super neat concept.
      Maybe look at a lest complex design where 1 or 2 plates slide in from the side(s).  This would be easier to seal.
        Valvetronic is wild
        • TehRaydarloverT
          TehRaydarloverT
          TehRaydarlover
          Should be able to cnc machine them no? I could use the machines at school for free. I was thinking of adding a tongue and groove along the edges of the shutters and like a teflon gasket between the moving shutters and those two center rings. With a little oil should be able to move and seal quite easily, in my mind lol.
          why would you even try to start it without a manifold lol how is doing that? I suppose it could still idle if the air flow meter was still plugged in
            the throttle is controlled by varying valve lift
            • TehRaydarloverT
              TehRaydarloverT
              TehRaydarlover
              GYPSY MAGIC I only speak m20.
                someone has done it, sure.
                http://www.ausrotary.com/viewtopic.php?f=4&t=205130
                check out this guys whole website dedicated to the topic/design of your camera 'aperature' style throttle:
                http://www34.homepage.villanova.edu/stephen.m.miller/IRIS%20Throttle/preliminary_ideas.htm
                basically, yes, the aperature style is more efficient, but its stupidly complex and really large in size, which would make it very difficult to use in an ITB setup, but not terrible with a single throttle.
                to me, cylindrical (used on F1 cars) or slide throttles seem like the best alternatives to the classic butterfly. both allow 100% unobstructed airflow at WOT, and are still simple enough (but still not as simple/cost effective as a butterfly)
                • TehRaydarloverT
                  TehRaydarloverT
                  TehRaydarlover
                  Looks like they are going to fit quite nicely. I need to do some research on what the diameters should be, I have seen anything from 36mm to 44mm, I used 40mm in the rendering. Can't go much bigger. Anyone have any input on ITB sizes for a 3.1l m20?
                  1545726102035356715788772127067696n.j
                  I also machined a crank spacer today.
                  165372210203535669698830848404531n.jp
                  160960910203535669778832999849017n.jp
                    The rule of thumb is to keep air velocity under 300 ft/sec to keep flow losses down.    V=CFM/(tb. surface area)
                     I would do 62mm for a single throttle body on a 3.1 with 7000rpm peak power (stock is 54mm I believe). Dividing that by 6 asks for 25mm individual throttles but thats not how ITB sizing works apparently:
                    "When sizing ITBs, you need to consider that each individual throttle needs to be large enough to not overly restrict air flow into its cylinder at high RPMs.  This required size is usually close to that of the intake port.  If you add the total cross-section area of each TB in an ITB setup, it will add up to an area noticeably larger that the TB size required for a single TB setup.  It is this characteristic that makes ITBs act like grossly oversized throttles at low RPMs.  This is why you want to also be careful to not select a TB size larger than you need because this will work against you at lower RPMs.  The smaller the TB, the better modulation you get at low RPMs and the higher the intake air velocity will be.  Higher intake air velocity helps air/fuel mixing and can noticeably effect performance.  EFI does not rely on the venturi effects that carbs do, but intake air velocity still effects performance.  The selection of an ITB size is then a compromise between these multiple design choices."
                    http://77e21.info/mstuning_tbsizing.htm
                    Everything I have seen for the M20 is in the 40mm range and I have read that the Dbilas setup is oversized (42 or 45mm, I cant remember)
                    Then there is also this from a throttle body manufacturer
                    http://www.jenvey.co.uk/jenvey/throttle-body-selection-with-jenvey-dynamics
                    Factors influencing size are; Power output, RPM, cylinder head design, cylinder capacity, position of the throttle body in the inlet tract and position of the injector.
                    Choice of bore size is a balanced compromise resulting from the following;
                    1. A larger bore leads to lower flow resistance, but obeying the laws of diminishing returns.
                    2. A smaller bore leads to better throttle control and response (never underestimate) and improved fuel mixing.
                    3. The system should be considered in total - from (at least) trumpet flange to cylinder and proportioned accordingly.
                    Basic references for BHP per cylinder, assuming ca 120mm from butterfly to valve head and a max of 9,000 rpm are;
                    Up to 30 BHP - 30mm, up to 33 - 32mm, up to 39 - 35mm, up to 46 - 38mm, up to 51 - 40mm, up to 56 - 42mm
                    Up to 65 - 45mm, up to 74 - 48mm, up to 80 - 50mm, up to 87 - 52mm, up to 93 - 54mm.
                    These power figures may be increased by up to 10% in a purpose designed and well proportioned system.
                    As butterfly to valve distance increases, butterfly size will need to increase in proportion to system taper and vice versa.
                    Lower revving engines and those with injectors placed before the butterfly will generally accept a larger body.
                    • TehRaydarloverT
                      TehRaydarloverT
                      TehRaydarlover
                      Nice info, I have the current design at 40mm. I have a spare 885 head and was thinking of trying my hand at porting the intake runners. Then using the MSOE's flow bench to get a flow rate and size the throttle body off of that. I'm thinking that without the butterfly valve at WOT there would be fewer losses and I would need a smaller throttle body, but idk. I have been talking with my senior design adviser, Dr. Kern, and he gave me a bunch of reports on how to properly size the intake box, going to be looking into sizing it for a 3.1l stroker. I also need to look into how velocity stacks are done... Here is my current setup. I added a 45* to the edges of the shutters which made it a bit more complicated, but I also worked out a way to open the valves. lol I posted a picture on r3v and people got excited, one of my class mates wants to make it for me at Snap on. I still need to talk to the machinists at MSOE and get their input on tolerances and their overall opinion on machining it.
                      151969210203572050368324532886559o.jp
                        what would you do for a throttle position sensor?
                          Still seems overly complicated for what it is.....not denying the cool factor though.  TPS could be contected to whatever actuates the rotational motion that makes the plates move.
                          • TehRaydarloverT
                            TehRaydarloverT
                            TehRaydarlover
                            Yeah it's defiantly over complicated for what it's worth, its more a "see if I can do it and make it work" type of project. I'm guessing I am going to need some sort of gear/pulley ratio so that full throttle for the accelerator peddle is full throttle for the throttle bodies. Should be able to attach it to that some how.
                              Yes, you will need to create a lever arm that allws the pedal to fully open close the throttles, this is the same that they do with conventional plates.  The machining and precision is going to be super important as well.  I get geeked out by this sort of stuff, so please keep posting updates.
                              Thanks!
