I started yesterday by rounding up a rubber tipped air nozzle. I got the pistons to pop right out.
I saw how nasty the face of the pistons were so I figured they could use some cleaning up.
Only one has a good bit of corrosion.
I think it should be fine since I wasn't having any issues with it before rebuilding these.
I dropped the caliper bodies in the parts cleaner yesterday to get all of the brake fluid out of the bore. I then stopped by the hardware store last night and grabbed some rubber plugs to block off the holes for the piston and brake line while they get sandblasted/powdercoated. I should be able to get them nice and clean by the end of today=)
Because show car!!
I will be out at the shop Saturday if anyone wants to stop in. My buddy Kyle will be making it out and I am hoping to accomplish something.
If there is an e30 318is trunk spoiler in said shop this guy will be there with smiles. If no spoiler there will only be dirty looks....
What company did you go with for the rebuild kit?Â
I need to rebuild my rear calipers soon.
It'll be there=)
I will most likely get the Centric parts. If they don't fit I will bite the bullet on the OEM kits.
My buddy Kyle had to work again this weekend so no progress was made on the bay.
I got out to the shop on Sunday.
The calipers, carriers, and knuckles where picked up to get powdercoated.
I also traded a set of Style 5 barrels I had laying around for the battery cables from an e36. This makes moving my battery to the hatch basically plug and play.
I started off by removing my hood latches so that I can clean them up and paint them.
My friend John then told me to get back to work on the trunk setup. I got the base for the compressors and manifold cut. This fits right inside of the tool compartment under the floor.
I will be mounting the compressors and manifold once I decide what orientation I should put them. After that I will cover the board in fabric to finish it off. You won't see it once I make the false floor, but I still want it to be aesthetically pleasing.
I was hoping to work on the motor but realized that I need the cam locking tool still. I will be borrowing one next weekend. That will let me get the timing chain back on and then I can button up the timing covers and get the valve cover on as well.
This week my rotors should be showing up too=) I got my taxes done on Saturday so I will have a good chunk of money to splurge on more parts
Hahah. 10/10. Would read again.
LMFAO!!!!!!
That put a huge smile on my face!
NM, found your post on BFC, if anyone else is wondering.
http://forums.bimmerforums.com/forum/showthread.php?1948071-E36-fuse-box-relocate
Where did you put everything?
