I decided against the brass bushings as from my reading it appears they need to be disassembled and lubed frequently, as in a couple times a year. I haven't had any issues with uneven wear using the stock setup, I will be using braided lines when I put mine back together, the pedal should have good feel with ABS delete and braided lines.
Also what sort of blaster do you have?
That's the thing that is swaying me away from them. I wouldn't really mind lubing them regularly since they're easy to quick disassemble. CaTuned is coming out with braided stainless e36 lines and I am getting them for my fronts as soon as they get in next week=)
I just looked at RockAuto and my mind was blown yet again. They have the carrier guides and bushings for dirt cheap. They even seem to have rear rebuild kits for over $30 cheaper than anywhere else. I might as well just get it all from them and see how it works out. What do you guys think?
The lube and relube thing is what initially came to mind....although I didn;t even know they existed. I suppose it's probably what race cars use, which would make sense as everything is rebuilt every race or 2. I think you would want the rubberized ones just for the longevity, even though they are not as high performance.
Note: I almost always go for high performance over just about anything else.....but having to relube the brakes a few times a year is enough to make me turn away.
can you find out who makes the cheaper units? They might be an off brand with lower quality standards. Sort of like when you buy from pelican, they have OEM, OEM supplier, but not branded, then offbrand 1 and usually offbrand 2. Gets cheaper each time, but, depending on the part, sometimes it's not worht the money saved on the off brand. This is especially true when looking at suspension, drivetrain, and braking components.
^This, I don't like doing stuff over because of crap parts. Not saying RA is bad, just in general. I bought a cheap replacement radiator support for out Maxima because it was rusted out and not only was the fitment terrible but it was so much thinner than the OEM part that It couldn't even support the engine cradle. I had to make a reinforcement from angle iron and weld in to hold it all together.
I have used Centric brake parts before and they seem good. The rotors I have gotten were from Canada in fact.
Canadia parts on a German what has this world come to????!!!!!
its just any time you get on the brakes the car probably asks "you sure you wanna stop eh?"
I started yesterday by rounding up a rubber tipped air nozzle. I got the pistons to pop right out.
I saw how nasty the face of the pistons were so I figured they could use some cleaning up.
Only one has a good bit of corrosion.
I think it should be fine since I wasn't having any issues with it before rebuilding these.
I dropped the caliper bodies in the parts cleaner yesterday to get all of the brake fluid out of the bore. I then stopped by the hardware store last night and grabbed some rubber plugs to block off the holes for the piston and brake line while they get sandblasted/powdercoated. I should be able to get them nice and clean by the end of today=)
Because show car!!
I will be out at the shop Saturday if anyone wants to stop in. My buddy Kyle will be making it out and I am hoping to accomplish something.
If there is an e30 318is trunk spoiler in said shop this guy will be there with smiles. If no spoiler there will only be dirty looks....
What company did you go with for the rebuild kit?Â
I need to rebuild my rear calipers soon.
