561 Posts 19 Posters 6.3k Views 1 Watching
    Also, I just picked up the obx manifold. Tons of good reviews on it as its a 666 copy, and they seem pretty strong. They made over a 1000hp with it so ill be good? ill be bracing it as well. I ditched the twin wastegate thing as I didn't think I should need to bleed off much boost ;) My fuel rail is getting here next wednesday, So Ill be able to finish up most of the install. Ill upload a shit load of pictures next weekend after the manifold gets here.
      What fuel rail are you using?
        I order fuel rail stock from Threadstone or something. Ordered all my fittings from Anfittingsdirect or something. -8 male to 1/2 NPT on each end, and I haven't ordered anything for the return yet, but I'm guessing I'm going to have to weld a -6 in.
          Need a spare block for building my main caps and girdle! Anyone?
            I'm stupid and should have bought a different manifold but it will do for now. My turbo is t3 exhaust housing split, but the manifold is t4 open(future turbo). So I built an adapter quick at work. 1/2" thick mild steel. Cold rolled. I still have to ball end it but I had to eat dinner and I'm impatient(I'll probably do it tomorrow).
              Fuel rail still isn't here yet.. Anyways. Does anyone know the size of exhaust manifold nuts for m50? Serious question.
                Realoem is your friend.  11721437202.  I believe they are a 7mm thread, the oem ones are copper and have worked well for me.
                  Yea I did that. I just wasn't sure 7mm was real.. Alright thanks! You guys will finally see a turbo mounted.
                    Could not find anywhere that had that size.....
                      Yes definitely an odd size.  BMW just has to throw some curve balls in there.  The strangest thread pitch combo I have seen is on my Land Cruiser the seat belt bolts are a 7/16-20.  The reason I found for that is so that they do not get mixed up at the factory and use the wrong bolts because every other piece of hardware on the truck is metric.
                        Anyone know where I could find the nuts local? I wanna hurry this up. Haha. Hey I guess they gotta do what they gotta do.
                          Probably can't get the correct copper ones locally.  Pelican is always really fast, and free shipping if you buy $75
                            Yea I just wanted something so I could mount up my turbo and finish the fucker. I can really only work outside on the car on the weekends. By the time I heat up the garage enough to do anything on the week nights, it's bed time(8pm- get done with work at 5.) so I just wanted to find something local so I can get some stuff done. But anyways, I ordered from the carr
                              Rowleym said:
                              I'm stupid and should have bought a different manifold but it will do for now. My turbo is t3 exhaust housing split, but the manifold is t4 open(future turbo). So I built an adapter quick at work. 1/2" thick mild steel. Cold rolled. I still have to ball end it but I had to eat dinner and I'm impatient(I'll probably do it tomorrow). 7amaby3u.jpg
                              More Pics!
                                More Pics!
                                Tapatalk finally works on my phone now so you guys will have a bunch of pics here shortly.
                                  So my turbo didn't really fit with that manifold... So I cut some of it off. jysama8e.jpgdata9usy.jpge6u5uty7.jpg
                                  Fuck you and your 5 bolt flange.
                                  Sorry.
                                  Anyways, I'm welding a v band flange into it. Not sure if 4" or 3.5". I want the smallest one but the smallest I think I could fit would be 3.3" anyways I'll have to look into how they measure v bands.
                                  Got the turbo mounted, but my brother is in the garage and it's a little bit too cold out to work on it. So.. This weekend!
                                    So I acquired a piece of 6061 .500 thick 6" diameter aluminum to use as a surge tank. How much volume do I need?
                                    I am thinking of mounting the dual 044's inside the tank. I think it would be much cleaner and I've seen it done. FUEL RAIL IS STILL NOT HERE DAMNIT. ytura3uj.jpg%20u5aje6er.jpg
                                      Nice slice!
                                        Nice slice!
                                        Yea worked out real nice haha. I tried milling it, but it was damn hard to he on to. It works!
                                          Awesome! Wish I worked in a machine shop, so many toys  :cool:
