  3. New Member Introduction
  4. 88' E30 IX
88' E30 IX
29 Posts 12 Posters 512 Views 2 Watching
  • TehRaydarloverT
    TehRaydarloverT
    TehRaydarlover
    I was advised this:
    measure the shaft diameter
    throw the bearing in a lathe and machine it
    press it in
    use a brake cylinder hone to get it to tolerance
    touch it up with a green scotch brite
    .001-.0015" clearance,002" max
      Yep, I didn't have access to a lathe so I took it all the way with the brake cylinder hone, it just takes forever, the problem is the stones plug up from the bearing material very quickly.  Once the stones were broken in the left a very nice finish though and then I wrapped a strip of scotch brite around the hone and used the drill to polish it evenly.  Keep everything oiled and the finish should turn out good.  Worst case is try it again, the bearing is less than 10 bucks.
      • TehRaydarloverT
        TehRaydarloverT
        TehRaydarlover
        Yeah I planned on getting two of each just in case. I was thinking I could probably do it at MSOE's machine shop and maybe have one of the techs help me with the machining. While I'm there I also need to machine the intermediate shaft itself to clear a 89.6 stroke crankshaft. Do you remember about how much you had to take off for it to fit?
          I just did a stock rebuild on a 2.5 so I didn't have to do any machining to the shaft.
          • TehRaydarloverT
            TehRaydarloverT
            TehRaydarlover
            Sorry that was out of order meant the bearing. How undersized was the bearing?
              Oh, if I remember right about 10 to 12 thousandths.
              • TehRaydarloverT
                TehRaydarloverT
                TehRaydarlover
                Alright sounds good, thanks!
                • I
                  I
                  industrialsized
                  if you get me the bearing and the exact dimension you want i can throw it on an id grinder at work
                    This would be interesting to see how well it works, the bearing material is so soft that it might gum it up.  It clogged the stones of the brake cylinder hone in seconds even with lots of oil.
                    • TehRaydarloverT
                      TehRaydarloverT
                      TehRaydarlover
                      The first machining would be just to get it close. When you press the bearing in its going to change the inner diameter a little. With the bearing pressed in use the brake cylinder hone to get it within tolerance. To do it right you need to machine it with the the bearing pressed into the block. I might try and press it in and use the cnc machine here at school.
