  3. New Member Introduction
  4. 88' E30 IX
88' E30 IX
29 Posts 12 Posters 512 Views 2 Watching
  • mkoeppM
    mkoeppM
    mkoepp
    Welcome,
    Very sharp car.
    I have never ridden in a IX. Handling must be great!
    • TehRaydarloverT
      TehRaydarloverT
      TehRaydarlover
      Thanks guys,
      I'm a senior ME, on the SAE Aero team for senior design.
      This is my first e30/bmw/car that is actually mine. Spent about 3 years looking for a nice unmolested non rust bucket. Ended up buying it from a guy in Lansing, MI. I've put probably around 3,000 miles on it and have had a single problem. Can't explain how much fun this car is to drive.
      Here is a crappy panoramic pic of the interior:
      644330102012410085337351280509439n.jp
      So far I've just been doing maintenance, grease front drive shaft splines, timing belt etc. I'm going to take it back home for the winter and fix the hole in my exhaust hopefully repair some rust.
      My plans for after I'm done with school and actually have money are to a stroker build and overall restoration.
      I was able to buy basically the front of an ix for $100 off craigslist. Included the block, oil pan, front diff, sub frame, steering rack, new control arms, cv shafts, power steering pump, ac compressor and more. Kinda crazy lol. Everything supposedly came out of a 120k ix and judging by the original cross hashing I'd say it was pretty well taken care of. Still kinda debating whether to use my original engine for the stroker build or this one...
      post-3378-0-10392500-1383435804thumb.jppost-3378-0-31765200-1383435818thumb.jppost-3378-0-54406300-1383435834thumb.jp
      I also bought a drive shaft spline upgrade from a guy in Finland off r3v. It increases the spline touching area length from 18mm to 50mm. This is kinda the first weak point in the ix drivetrain when it comes to an increase in power.
      1234767102023722294535511753833797n.j
      • I love my E39I
        I love my E39I
        I love my E39
        welcome to the forum!
        -Because Racecar-
          18mm is factory spline contact area? Jesus that is small. That's definitely an upgrade!
          • TehRaydarloverT
            TehRaydarloverT
            TehRaydarlover
            Yeah this increases it to 50mm. On the down side you have to drop the transfer case to put it in, but then just grease it with the zerk fitting.
              Welcome, welcome! Another MSOE guy, eh? I went there for AE. Good to see another MSOE bmw here. Great looking ride!
              • Dominic540D
                Dominic540D
                Dominic540
                Always nice to see another guy from MSOE. I'm currently a junior ME there. Love the ix
                • S
                  S
                  SunD3v1L
                  Wow, awesome! I really want one for winter use..
                  • TehRaydarloverT
                    TehRaydarloverT
                    TehRaydarlover
                    Did a little bit of work over winter break:
                    new odometer gears
                    lubed driveshaft
                    tore down my spare ix block
                    disassembled some spare parts
                    LOL one h&r one stock spring
                    m20 tear down
                    Got the upgraded driveshaft all ready for welding
                    I've owned my ix for almost a year now and my parts hoarding level is already over 9000!. Did a little inventory and I have about 1.5 complete ix drivetrains and only have $300 invested :D I kinda want to buy a beat ix and do some rallying!
                    Went to my friends bachelor party and my ix and I both woke up lost in the woods with matching faces :blink:
                    Also did some interior decorating when I got back to school :cool:                          ...someone buy this e28 seat it keeps falling over :angry:
                    That is all
                      Is that scored bearing for the oil pump secondary shaft?  Those suck to replace, if they are in ok condition just leave them alone but obviously that one isn't.  Can you see how that happened or was that from taking it apart?
                        Also curious about that bearing bore.
                        How were the odometer gears to replace? I need to do mine soon.
                        • TehRaydarloverT
                          TehRaydarloverT
                          TehRaydarlover
                          Yeah it's the oil intermediate shaft bearing. I don't understand how it happened the engine has 120k on it and everything else is fine, the second bearing behind it is perfect. I'm thinking the oil passage must have been blocked somehow? There was really no sludge build up or any other signs of excessive wear. I guess on the plus side I can now safely hot tank the block while its out.
                          The odometer gears were a breeze, the hardest part of the project was getting the instrument cluster out/in before frostbite sets in lol no heated garage
                            How does the shaft look?  I have the numbers for the bearings stashed somewhere, I will find them and let you know.  BMW will not tell you the numbers, and they will not show up on realoem but they can be gotten for only about 8 dollars each if you know the part number.  I would even leave the other one in and see how it does during cleaning.  They are a massive pain to reinstall, they are undersized and must be honed to fit after being installed.  Probably had 8 hours in fitting those bearing on the m20 I rebuilt and still don't know if it's right cuz it hasn't been started yet.
                            • TehRaydarloverT
                              TehRaydarloverT
                              TehRaydarlover
                              The shaft looks fine, surprisingly. These are the part numbers I have for the bearings:
                              11 11 1 264 196 - BEARING BUSH
                              11 11 1 280 863 - BEARING BUSH
                              If I'm not mistaken Bravauto actually sells them.
                                Yep any place should sell it if you have the number.  I got mine from Pelican, have you looked into the honing process?  I did it pretty redneck style.
                                • TehRaydarloverT
                                  TehRaydarloverT
                                  TehRaydarlover
                                  I was advised this:
                                  measure the shaft diameter
                                  throw the bearing in a lathe and machine it
                                  press it in
                                  use a brake cylinder hone to get it to tolerance
                                  touch it up with a green scotch brite
                                  .001-.0015" clearance,002" max
                                    Yep, I didn't have access to a lathe so I took it all the way with the brake cylinder hone, it just takes forever, the problem is the stones plug up from the bearing material very quickly.  Once the stones were broken in the left a very nice finish though and then I wrapped a strip of scotch brite around the hone and used the drill to polish it evenly.  Keep everything oiled and the finish should turn out good.  Worst case is try it again, the bearing is less than 10 bucks.
                                    • TehRaydarloverT
                                      TehRaydarloverT
                                      TehRaydarlover
                                      Yeah I planned on getting two of each just in case. I was thinking I could probably do it at MSOE's machine shop and maybe have one of the techs help me with the machining. While I'm there I also need to machine the intermediate shaft itself to clear a 89.6 stroke crankshaft. Do you remember about how much you had to take off for it to fit?
                                        I just did a stock rebuild on a 2.5 so I didn't have to do any machining to the shaft.
                                        • TehRaydarloverT
                                          TehRaydarloverT
                                          TehRaydarlover
                                          Sorry that was out of order meant the bearing. How undersized was the bearing?
