Megasquirting the e28 ?s
What snap said!!
I need some of you guys in my area lol. I'm a visual and hands on learner. And why swap to i head?
so you can use the "plug and play" e30 option. http://www.diyautotune.com/diypnp/apps/b55/usdm-bmw-325-8792-m20b25-mt.html
If I swap the head my compression lowers doesn't it? Better for boosting then???
Rowley, are you telling me that you can run wasted spark on 1 coil driver?!?!?
Im not doubting or anything, I haven't read up much on alternate ignition setups so I may learn something from you here.
Oh hey I forgot about ms2 only having one. I have MS3 so I went with the easiest setup...
So snap did you just buy a MSPNP2 and did plug and play or did you make your own board?
How much did that run you and can you tune a n/a base tune and do a turbo tie after the fact?
650 and worth every penny, I already had a wideband (strongly recommended but not a necessity)
but to be realistic, a wideband, GM intake temp sensor, bung, misc air intake mods, and M50 TPS + adapter would probably get the total price around a grand.
http://www.r3vlimited.com/board/showthread.php?t=202653
I still have the NA tune on the ECU but it would take a whole 5 minutes to make it work for my new bigger injectors and a turbo (fine tuning required of course). I will probably do that tonight.
the cost shouldnt freak you out, but one way to look at it is, if your car rusts out, canadians stab it with popsicle sticks, or if earl polishes every bolt on it, you can take the ecu and use it in any other car (monte carlos, bitchin camaros, integras, vw cabriolets etc) as long as you make the appropriate changes in the tune (change number of cylinders and injector size for example) and adapt the wiring harness to work.
could they build one up of the dme in my e28???
If I had someone to learn megasquirt from in the first place I could have saved a little money and bought the DIYPNP assembled ecu from diyautotune.com but I had to figure it out by myself with the internet and whatever infrequent emails or PMs I could receive from others.
The only thing youd be missing by getting a DIYPNP vs one built into a e30 ecu is that whodwho incorporates a circuit in the ecu that allows you to use the stock e30 TPS, but this is not desirable, a variable TPS like what an M50 has is far superior for tuning and running the car.
You could get the DIYPNP setup with the bosch 55pin harness (stock e30 325i ) so you would just need a 55 pin harness on your car to connect into it, then get aluminum plate, drill some holes in it, mount the ecu to the plate, and the plate to the stock ecu location.
I actually bought the DIYPNP setup and built it, and then realized I wanted something more universal and have more features. Don't be scared at the wiring and stuff. I would be more scared to build the board! I say you should buy a ms3 and gut an old e28 ecu case if you want it plug and play, and wire the necessary connections to it. I say buy something Pre-assembled.
If the e21 came with an ecu and someone made a PNP megasquirt for it like they do for the e30, I would of spent the extra money in a heartbeat. But since I had no choice, I went the used route and bought a board already assembled and will be having the joy if wiring everything up to my engine sensors soon.
So if I were to swap on an i head on the m20 i have in the e28 can i just run a piggyback to the ecu and control the spark and fuel and not have to swap over all the shit from the i head vehicle?
