  3. BMW Discussion
  4. Just added bluetooth through factory radio in 08 X3
4 Posts 3 Posters 0 Views 1 Watching
  • U
    U
    urbanassault745
    Check out this bluetooth handsfree system we just installed into a 2008 X3, it plugs into factory radio, the factory radio harness then plugs into our t-harness so you can stream music via bluetooth or take/make calls.
    • S
      S
      SwissCheeseHead
      Nice mod.  Can't live without bluetooth these days.  Should be standard on all BMWs since every other car manufacturer has it standard.
      • U
        U
        urbanassault745
        Right exactly. We also did heated seats on it which was fun since you can not unplug the seats from the floor unless you want to set off the airbag light...But took some wiring extension to get the bluetooth control up there since the wire was too short to reach the back of the radio, so had to cut open the cable and solder about 10 mini wires on each side of the cut. Results were worth it though, and crystal clear sound.
          Very sweet!
